I was reminded by the Pict'Earth guys last weekend that one of the best all-purpose planes for carrying cameras, GPS recorders and any other sort of equipment you want to test is the Multiplex EasyStar, a virtually unbreakable powered glider. Because it's made of elastopore foam you can carve out the equipment compartment to carry pretty much anything you want, and the same foam protects everything in case of a "hard landing".
EasyStars are available for $54 without the radio equipment. This post is just a quickie to show you what else you'll need top make them good UAV platforms.
Although the kit comes with a brushed motor, I suggest you upgrade to a brushless so you can carry heavier loads with ease. This motor is a perfect fit and has power to spare. I matched it with this ESC. As always, you'll want Li-Ion batteries if you can afford them. An 11.1v, 2200 mAh pack will allow you to fly for more than half an hour under power. A 6x4 prop fits perfectly
For a radio, almost anything with six channels or more will do. The EasyStar has compartments pre-cut for servos; the HITec HS81s fit them best.
Finally, here's an important point. With the more powerful brushless motor, you'll find that rudder is really too small to be effective. You need to make it bigger to increase its "authority", which both helps in more extreme moves and at slow speed. The easiest way is to glue or double-sided-tape two business cards to the rudder. Here's a picture of one such mod (I didn't bother to trim mine as neatly as this guy did): Once you've done all that you can shove all manners of cameras and such in the equipment area. If you don't want to carve holes in the bottom, you can always just bolt a camera to a bit of wood and strap it to the top, like this.
I will take a look.
Best,
Z
Thanks!
http://www.rangevideo.com/index.php?main_page=product_info&cPat...
But it glues together great! At this point my original EZ is mostly glue.
Anyway, calling the Easy Star "Indestructible"- Har har. I put that to the test. I'm currently putting it back together. I bought it so that I could follow your project to the T (I even went so far as buying the radio and servos you recommended). When I flew today it was windy and it seemed like I had no left turn capability. I didn't upgrade the motor or add the rudder extension, but I'm wondering- is it possible to fly this thing in 10 mph winds?
It's so light that I'm inclined to say no, but then I start thinking, "Wait a minute. It's a freaking glider!"
I'm going to glue this sucker back together and make the rudder larger and see how it behaves in zero wind.
1
2
3
4
5
of 5 Next
