I was getting lots of vibrations from my Hextronik DT750 even after balancing it and using balanced props. I replaced the bearings and now the motors are like new!
The steps for DT700 and DT850 are similar
To remove the C-Clip, it would be easier if you use a snap-ring plier (unfortunatelly i don't have one hhehehe)
Sim, no sentido do eixo, que é o mais solicitado
mais os rolamento TRUST sao para forças em outro sentido certo ?
Filip, those bearings are useless so you could even break them. You just have to pay attention when insert the new ones
Magnus, i've bought some of HK450v2 bearings. They aren't quality bearings but better than the default bearings. Just search for "HK450V2 Bearing (8x4x3mm)" in google (i don't know if i can put the link directly to hobbyking). You can find quality bearings in boca bearings
eduardo, o ideal seria usar rolamentos radiais e axiais ;). It would be better to use thrust bearings besides the radial bearings
Nao adianta trocar os rolamentos desse motor. Logo logo eles vao estragar denovo.
Para ficar bom voce tem que colocar 2 rolamentos na parte de cima. Para isso tem que passar a parte central no torno para aumentar o profundidade do buraco.
Essa tecnica é muito usada em outros motores.
Where do I get new quality bearings?
Nice guide but I would have used either a plastic tap or a softer metal like brass or copper when pushing out the bearings.
