3689637759?profile=original
This is a new Android App for running a Heads Up Display on a SmartPhone or table computer or Windows. It's available on the Google Play store at https://play.google.com/store/apps/details?id=org.qtproject.qtgstreamer
If you want to side-load, I have posted a free version on dropbox at https://www.dropbox.com/s/g38tv79z3ey8yks/QtGStreamerHUD.apk?dl=0
There is also a windows version available at https://www.dropbox.com/s/km52szl7ghdo15a/GStreamerHUDApp.msi?dl=0
This app will overlay the HUD on a video stream using GStreamer, or you can run the app without video with a normal HUD.
The App will automatically listen for a MAV-Link data stream on UDP port 14550, the default UDP port for MAV-Link. You can also configure the app to use TCP, and on windows you can connect directly to a serial port.
If you want to display data on a ground station PC and the App at the same time, you can use MavProxy to split the UDP stream, and then connect to your UAV using Mission Planner.
Here is a sample command that I use to split the data stream with MavProxy:
mavproxy --master=COM5,115200 --out=192.168.0.1:14550 --out=192.168.0.126:14550
The ground station PC is at 192.168.0.1, and the SmartPhone is at 192.168.0.126 (on my wifi network).  You will have to configure the IP address according to your own WiFi network. My WiFi network in the field is a Ubiquity Rocket M5 configured as an access point, and a second M5 is on the UAV, so I can get live video from the UAV over the same network that connects the smartphone.
For the windows version, you can run the HUD on the same PC as MissionPlanner (or APM Planner), and use MavProxy with a different UDP port for the HUD.
If you want to use the video overlay, you will need to have a valid gstreamer data stream running, either over UDP or TCP.  For my setup, I am using a Raspberry PI streaming H264 over UDP using this command on the PI:
raspivid  -t 0 -w 1280 -h 720 -fps 40 -b 4000000 -o - | gst-launch-1.0 -v fdsrc ! h264parse config-interval=1 ! rtph264pay ! udpsink host= $1 port=9000
The "$1" argument is the IP address of your GCS or SmartPhone/Tablet PC.   This command is for 720p, but you should consider the resolution of the device and adjust accordingly.  It makes no sense to send a 720p video to a phone with a 800x600 display.
In the HUD, configure the gstreamer pipeline with this string:
udpsrc port=9000  buffer-size=60000 ! application/x-rtp,encoding-name=H264,payload=96 ! rtph264depay ! h264parse ! queue ! avdec_h264
Do not include a video sink element, as the App will add this dynamically.  You can change the port to whatever you wish as long as your PCs do not have a firewall blocking the port.
Another thing to consider is the processing power of your device. If you see a lot of pixelation, your device is too slow, so you will need to change the resolution of the transmission and/or the bitrate. Some smartphones are just too slow to display the video at full resolution. I have tested 720p on my Google Nexus 6 and it works fine, but on a cheap tablet PC, I had to slow it down and switch to 800x600.
The App is easy to setup, however if you have any questions or issues, please send me feedback.
Happy Flying!
  • Another tip on connecting your Android  device in the field to the video/telemetry.   If you are using a laptop PC with Windows 7 or Windows 8 for your GCS, you can create a 'Wireless Hotspot' and connect your phone/tablet to the laptop, with 'ICS' (internet connection sharing).
    To enable the hotspot, use these commands in "administrator" mode in a cmd window:
    netsh wlan set hostednetwork mode=allow ssid=YourVirtualNetworkName key=YourNetworkPassword
    Start the Wireless Hosted Network:
    netsh wlan start hostednetwork
    Then on your LAN adapter that is connected to your Rocket M5, enable ICS (right click, properties, sharing tab, enable).
    You should be able to connect your phone to your laptop by a wifi connection with the name you picked for 'ssid'.  Also, you may want to use a static IP address for your device so you can create the gstreamer pipe without having to constantly lookup the device's IP address.
    To get the telemetry going to multiple places, I used this string for MavProxy:
    mavproxy --master=COM2,115200 --out=192.168.137.3:14550 --out=127.0.0.1:14550 --out=127.0.0.1:14551
    COM2 is actually a virtual serial port on my machine, which connects to the Rasperry PI on my UAV via TCP.   If you are using UDP on your remote, you can connect directly with MavProxy without the virtual serial port.
    My Nexus 6 phone is at IP address 192.168.137.3, and the local machine running Mission Planner will connect to port 14551, and the stand-alone version of the HUD will connect to port 14550.   If you are using the Mission Planner version of the HUD, you only need one local connection.
    Then in the HUD, I use this string to get the video on both the GCS and the phone at the same time:
    udpsrc port=9000  buffer-size=60000 ! application/x-rtp,encoding-name=H264,payload=96 ! rtph264depay ! h264parse ! tee name=split ! queue ! avdec_h264 split. ! queue ! h264parse config-interval=1 ! rtph264pay config-interval=1 ! udpsink host= 192.168.137.3 port=9000
    Fortunately, you only have to set this up once, but it works!
  • @bocorps, if you are using the Mission planner version, the HUD gets everything from the same link as MP, so it would appear that MP is somehow losing the connection.  If you are using UDP port 14550 you should leave the 'connect' field blank as the HUD will always listen on that port.
    If the video link is ok, it's weird that you would lose telemetry. Did you check all your connections for lose wires?
  • @bocorps.  Your phone is too slow for video.  My nexus 6 can do 800x600 without any pixelation, and I have a tablet that also works pretty good.
    To change the port, you have to edit the string, then hit "Enter" on the keyboard (or Accept on Android)  to make the control add it to the list. Otherwise it forgets your changes.
    Are you sending telemetery to port 14550 on the phone?  Not sure why your telemetry isn't working, but if you are getting video, it should work if you are sending data to the right port.
  • FYI, a tip for streaming the video to your phone is to use a standard WiFi router connected to your GCS, and then connect any device to the WiFi router. An example gstreamer pipeline, you can split the stream and send it to your phone, or even multi-cast the stream. Here is a sample pipeline I used to send the video to both the GCS and my phone.
    udpsrc port=9000  buffer-size=60000 ! application/x-rtp,encoding-name=H264,payload=96 ! rtph264depay ! h264parse ! tee name=record ! queue ! avdec_h264 ! video/x-raw, format=I420 ! d3dvideosink sync=false record. ! queue ! h264parse config-interval=1 ! rtph264pay config-interval=1 ! udpsink host= 192.168.0.143 port=9000
    The phone is at IP address 192.168.0.143.   You can configure your phone to have a static IP if you don't want to constantly edit the pipeline.
  • @bocorps,  one note about connecting the phone to the M5.  Your phone needs to have Wireless-N dual-band, which most phones don't.  I am using an Android tablet PC that has 5ghz wireless, so my last post may not work for you unless your phone has dual-band ability.
  • @RogerCon,  I have posted the XP version on the dropbox.  I think it works, but I would like somebody to verify it.
  • @bocorps,   You should connect the phone via WiFi.  But the trick is to configure your ground M5 to be a normal access point (not Ubiquity 'Airmax' TDMA/MIMO). Set the bandwidth to 20mhz or your phone won't see the access point.  For 85% of the folks out there, you can disable AirMax and still get the range you are interested in.
    You have to configure your remote M5 to also use standard WiFi with a 20mhz bandwidth, and then you can connect both the remote M5 and the phone to the ground M5, and the M5 acts as a wireless router.  You can connect your ground PC also using WiFi to the M5, but you still need a POE to power it.
    Once you have both your phone and GCS connected to the ground M5, you can run MavProxy on the GCS to send the MavLink data to your phone and the GCS.  The video can also be sent to the phone is the same way. On your remote, just use the IP address of the phone when you start the stream.  I'll be posting a blog with a video later on how to do this.
  • I will try the above when I get back to our shop. Will try the XP if its ready too. thx!
  • @RogerCon,  So you want to start the HUD with the pipeline string on the command line?  That's easy to add.
    I have added a feature where it remembers any new strings and adds them to a drop list.  Currently it only has a place for one string, so in case you have a 'record' and 'display' version, you can easily switch between them, or any version you want.
    I have the XP version compiled, but I have not tested yet.  I'll add that to the dropbox after I blow the dust off my XP machine and give it a try.
  • That should work.
    I use the following batch file:
    set hr=%time:~0,2%
    if "%hr:~0,1%" equ " " set hr=0%hr:~1,1%
    gst-launch-1.0.exe -e -v udpsrc port=9006 buffer-size=60000 ! application/x-rtp,encoding-name=H264,payload=96 ! rtph264depay ! h264parse ! tee name=record ! queue ! avdec_h264 ! video/x-raw, format=I420 ! timeoverlay ! d3dvideosink sync=false record. ! queue ! mp4mux faststart=true ! filesink location="./Videolog/Video_%date:~-4,4%%date:~-10,2%%date:~7,2%_%hr%%time:~3,2%%time:~6,2%.mp4"
    Using faststart=true puts the header at the beginning of the file as I could not get around the EOS usage.
    The reason for the "set" parameters is for the time format showing XXX_09:00 instead of XXX_ 9:00
    Any thoughts on how to incorporate the above file format on the hud command line?
    beginning - Google Search
