I have clinical multi-projectitis.
It's incurable.
After seeing the GRASP lab video sof quads literally jumping through hoops, I HAD to make one of my own.
The beginnings:
Although everyone else seems to be going open-rotor, I want zero collateral damage to people, pets, and the living
room walls, so I decided on a ducted-fan design.
4 EDF combos from Hobby King
https://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=11166
Combined thrust of 4400g.
Combined mass of 424g.
The 5Ah 4S 40C LiPo from my currently grounded Swift Heli:
https://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=10307
Mass: 578g.
For testing, the initial fuselage is a chunk of extruded poly insulation.
5 Deans connectors and a new soldering iron later (the old 30Watt one couldn't make a decent joint for the wiring harness), this is the result:
I christen her "The Ugly Pink Quad."
At present, she's brainless. I just did a test with a little solderless breadboard sending the throttle signal to all EDFs simultaneously and, not surprisingly, things were learned:
1) With 4400grams of max thrust pushing 1220grams of pinkness, it only took about 1/3rd throttle position to hand-hover.
2) It wants to rotate.
Next issues: Basic landing gear (The motors are outrunners), basic brains, and an IMU
Ducted fans are totally enclosed, with a set of stator blades beneath. Essentially, if I were to dremel off the surrounding duct, and the stators, I would have a small, high speed propeller that had much less thrust.
Mostly I choose the ducted fan route to have a built-in finger/furniture/pet safety margin.
Unfortunately, the speed controller is toast, and lost a screw at less than half-power the other day, so the Ugly Pink Quad is on-hold/no more. The redesign will be a tri or bi-rotor, more robustly built.
Info soon.
@hamish, not quite sure I understand your post... but IYO what way is not wrong? ;)
If u vectored them , surely it would be stable when still, but would turn one way alot easier and faster than the other way?
u doin it wrong
Darren's idea is good too, BAE use it in their UAV.
1
2
3
4
5
of 5 Next
