My friend is a senior aerospace engineer at the aircraft certification division of Transport Canada and I am an aircraft maintenance engineer working also for Transport Canada as a civil aviation safety inspector.
That day, I challenged him into a project and he said with a smile; I hate you !
Since then, according to our wives, we are crazier then ever. We are now obsessed into accumulating enough honey-do list points to buy free time to go forward with our project.
I posted here a few pictures to tease your curiosity. If you want to play with me until the end you will get the complete story and details about what we created. All because of what DIYDRONES put in our heads.
We are planning to give most of it to the open sources community.
For me it started by looking and drawing on an autocad 2009 computer screen. Did I mentioned also self learning how to use autocad?
One of my neighbor, also a friend, bought from China, on Ebay, a $1500.00 CNC machine knowing that I would learn how to use it and then teach him. Sure... but before I had to put together a computer powerful enough from some of the junk found in my garage. Could not wait to find a case for it.
After going through a few online tutorials (or was it a lot?) about Mach 3 CNC software, Sheetcam CAM software, stepper motors and controllers, etc. I ended up with my case less computer showing this screen;
and a noisy set up doing that; At least that is what my neighbors complains at 3 o'clock in the morning, you know ! CNC, router and vacuum noises.
Realizing that honey-do points are very hard to accumulate, we decided to start with cheap and easily available trex rc helicopter parts and built around it. Also we had the wisdom to start with a mock-up made with acrylic instead of wasting some very exotic and expensive material like carbon fiber. I think they call that the learning curve.
But what is that gizmo?
The continuation of our story will be by acclamation from you guys or it will die with this post...
Are you curious? Did DIYDRONES made you crazier to? Maybe we should consider a class action for it to stop...
Cheers!
Mario
I know it's variable pitch, but my wild guess is that two motors will add power to all four motors(not two motors split with 1 motor per prop). I think all power from the two motors will be combined to give more power to all four motors. With variable pitch it would make more sense to have one source of power(even if from two motors) and a way to make two props spin one direction and the other two another direction and change pitch to stabilize!
My idea was much simpler which was to just add an extra twist to the belt of two of the motors. But I'm sure your prototype will function even better since I was going the cheap rout!
I'll be very impressed when you can use AP to have this thing follow way-points instead of just stabilization!
Dual poles allow personal control. Go.
can be built for around 800$
