We've changed the channel that reads the throttle on basic ArduPilot from pin 13 to pin 11. That's because pin 13 shares an LED, and it's causing problems with some low-voltage RC receivers. Pin 11 is clean.
The above picture shows the correct jumper wire configuration. If you've been using pin 13, please switch it to pin 11.
In the code, you tell ArduPilot which pin you're using with this line:
//3-1
#define THROTTLE_PIN 11 // pin 13, or pin 11 only (13 was old default, 11 is a better choice for most people)
Sorry about this messiness, but it's all in the service of extracting as much utility as possible out of the basic ArduPilot board (which was originally designed not to control the throttle at all--those were simpler days!). Later this year we'll release a new version of the ArduPilot board which will clean up everything nicely (same features, so nobody will be left behind), but for now, please whip out your soldering iron and switch the jumper.
The manual has been updated with the new instructions.
Here's the link for that users Guide.
Best Regards,
Nathaniel
Are you sure about that? Check out this clip from the Phoenix users guide:
Auto
Calibrating
Throttle*
Any fixed wing aircraft, but NOT for use with
helicopters. When using Auto Calibrating Throttle,
you must throttle up to full throttle for four
seconds and back to the off position each time
you power up and fly your airplane. This will
set the automatic throttle endpoints within the
controller. This is the FACTORY setting.
I don't use this because 4 seconds at full throttle is a long time of exposure to the potential risk of a prop strike with the ground, or a prop with hidden damage breaking apart. Not to mention it's a pain to hold on to a plane this large with a motor producing that much thrust.
Best Regards,
Nathaniel
Nathaniel
Auto calibrate is a programmable function on the Castle Creations Phoenix ICE ESC (and many others), as opposed to using fixed endpoint mode.
Nathaniel
I'll give that a try tomorrow. I have resisted doing this because I don't want to have to run up the throttle all the way to full power to calibrate the high end on the ground,and it uses up valuable power I could be using in the air! I'll try it though to see what I get. If I do end up using auto calibrate, would I need to run an auto calibrate sequence while in Debug_Subsystem 1 to find the resulting PWM values, and then use those values for the min/max ch3 values?
Nathaniel
1
2
of 2 Next
