Indoor fun with a tiny ArduCopter quadcopter
Do you have an Ardupilot Mega and shield and want some fun for little money? check this tiny quad... my last drone in family...
Some specs:
- Size : 26.5cm (10.4 inches) from motor to motor
- Motors : 18-11 200kv 10 gram motors
- Props : 4x2.5 (standard CCW props)
- ESCs : Turnigy 6A
- Battery : 3S610 (or 3S800)
- Sonar : Maxbotics LV-EZ0 [optional]
The nice part about this frame is that it use standard kite parts, so it´s very easy to construct and it´s perfect for some radical tests.
Itried to find a bit different design that also make the quad less simmetrical (it´s very easy to loss the orientation with a quad) and I wanted to do as small as posible to flight indoors...
At this size and weight it´s very safe and robust also. The props use prop savers and this help a lot in crashes...
I am not very good writing... so I took a lot of photos during the build phase and I created a build log:
https://docs.google.com/document/d/1fIZL-Ca2fx2RPhBQLzoOdqdCuikXRKePwKbxDlJWiss/edit?hl=es
This code supports a sonar for altitude hold and also has a battery alarm (2 alarms).
Thisquad works with ArduCopter code, but because how main board is mounted, actual code doesn´t work. This is the code that I used with this quad :
http://code.google.com/p/arducopter/source/browse/#svn/branches/Arducopter_indoor
(as zip format:
Arducopter_indoor.zip )
note that this will be integrated on main Arducopter code. Now is temporarily in a branch.
ThePID gains are different than in standard ArduCopter, so you need to Initialize EEPROM on Configurator or put this ones manually:
-Stable mode: P : 4.8 ; I : 0.12 ; P_rate (D in configurator) : 0.4 ; Yaw : (4.5 ,0.15 ,2.8 )
-Acrobatic mode : P : 0.75 ; I : 0.1 ; D : 0 ; Yaw : (2.4 ,0.2 ,0 )
OK, but was all so perfect like in the video? I don´t believe that...
Yes, you are right, but fortunately this design is very crash resistance... and this part is also fun...
After all this battles I only needed a few drops of ciano in the crash with the lamppost :-)
What´s the real size?
On center, standard arducopter frame, on left, old ArduIMU quadcopter part III, on right-top this project.
And what about the automatic aerobatics on video?
I am starting to test a new function to do automatic aerobatics (Automatic Aerobatic Procedure). The idea is that you enable this function with a switch in the Tx to make an automatic predefined aerobatic and then automatically recover to a stable mode.
Thisis actually a proof of concept but works very nice. One limit here is the maximun rate of the gyros, in our case 500deg/s. If we exceed this, the IMU get confused...
An interesting point to note is that the IMU doesn´t loose the orientation in this hard movements...
Thestory is that I have never feel too much confidence doing flips manually with quads. Then I start thinking that with an automatic code we can get a precise timing and controled movement so maybe this could help to do better aerobatics. I started testing this function outdoor, on an open field but I was improving the code and got more tightly maneuvers, so tight, that I ended up doing flips with a quad inside my room!!!
Here is the code I was testing : (AAP function:
AAP.txt )
I implemented this functionality as a state machine where there are three kind of states:
- fixed commands for a limited period of time. (example : Apply a throttle command)
- fixed commands until we reach some IMU state (example : roll until we reach a certain angle)
- And a mix between this categories and a control (example : Throttle command + stable mode on roll, pitch, yaw)
There are many things to test and improve here but the basic concept works very nice...
If I can get a bit of help from a friend, I will probably made a carbon fuselage for this prototype...
Enjoy this “Science & Fun” mix...
Jose Julio.
Arducopter Team
  • I also had trouble finding the right kite parts for the motor mounts. I ordered some, but they were the wrong kind. Still don't know where to get them in the US. I ended up making the motor mounts on our lab's CNC mill.
  • online....i can't find a store around me that has the kite stuff.
    i have these - http://www.kitesandfunthings.com/ProductInfo.aspx?productid=P2026 and have the "Y" (TAPA Y) size for the .156 tubing I ordered - solid - http://www.kitesandfunthings.com/ProductInfo.aspx?productid=CFMICRO and also hollow - http://www.kitesandfunthings.com/ProductInfo.aspx?productid=CFPULTT... again, both in .156 diameter.  If you can find the motor mounts, please let me know.  shipping was $10 fwiw.
  • Has anybody found the 'motor mounts' in the US?  I just received the frame parts and what the 'kite store' told me would fit for the motor mounts are a no go.  Everything else is inbound so I have some time as my other quads are much larger, but those motor mounts are becoming a PITA to find.
  • Hi, i have a question. will the new arducopter beta code work with this frame?
    Thank you very much!
  • Hi everyone. i have been looking for the block diagram of how this tiny quadcopter connected but cant seem to find it. Anyone has a link for it??? Thanks..
  • Is there any particular reason why the most current repository code 2.0.32 would not work on this quad? X configuration is now a standard part of the code, so the only thing that might give problems is not using a GPS! Or am I missing something else?
  • i have a question. All 4 motors turn the same direction, if yes which direction is it?
    I am a student just started working on this project. :)
  • I´ve got this props from HK. They are cheap and light .. but really bad. You need a hard work to balance each of them.
    Regards
    Angel
  • It seems that pusher/puller props are available in size 4x2.5 from HobbyKing. So could I just mount all motors normally (none of them tilted) and use clockwise/counterclockwise motor rotation like on the big quads?
  • Fantastico. Un trabajo esplendido.Estoy volando en Madrid el nuevo AC2 2.0.31 y me gustaria adentrarme en el codigo. Me puedes dar algunas sugerencias?
    Por ejemplo, que compilador usais para el desarrollo. No se si tendras algo de documentacion general. Me gustaria hechar una mano.
    Me llamo Angel Fernandez. Soy ingeniero aeronautico y trabajo en EADS - Astrium en temas de espacio. En cierta manera hay similitud entre los satelites y esto.
    Soy afernan en DIY Drones y mi Email es afdiez@gmail.com
    Un saludo
    Angel
