Introducing the AUAV X2.1 Flight Controller
3689701263?profile=original
The AUAV X2.1 is all about lessons learned. The X2 was a very successful board but there was still room for improvement. Following the PixRacer project we had time to invest into making the X2 the high quality PixHawk replacement we intended it to be. Major changes include: updated IMU sensors, power supply has been redesigned, headers have been laid out more logically, remote USB connector, industry standard 30.5mm mounting points.
Questions and comments are welcome!
Phil and Nick
Available: October 1, 2016
Price: $130
Site: http://www.auav.co/product-p/auavx21.htm
Processors:
Main: STM32F427VIT6 ARM microcontroller - Revision 3
IO: STM32F100C8T6 ARM microcontroller
Next Generation Sensors:
Invensense MPU9250 9DOF
Invensense ICM-20608 6DOF
MEAS MS5611 barometer
New Power OR-ing schematic with reverse voltage protection. 5V power module is required!
Connections:
2.54mm headers:
GPS (USART4)
i2c
RC input
PPM input
Spektrum input
RSSI input
sBus input
sBus output
Power input
Buzzer output
LED output
8 x Servo outputs
6 x Aux outputs
USART7 (Console)
USART8 (OSD)
JST GH connectors:
CAN
USART2 with flow control (Telem 1)
USART3 with flow control (Telem 2)
USB (150mm GH to Micro USB cable included for convenient mounting)
JTAG FMU Processor
JTAG IO Processor
Size: 36mm x 50mm
Mounting Points: 30.5mm x 30.5mm 3.2mm diameter
Weight: 10.9g
3689701163?profile=original
3689701239?profile=original
3689701276?profile=original
3689701305?profile=original
  • No, the same sensors as of the Pixracer, but HMC5983 which is obsolete and there is no equivalent on the market.
    I hope that the code porting will not take long as the MPU9250 and ICM20608 drivers are well developed and working fine in Pixracer.
  • So different sensors than Pixracer?
  • MR60
    Rob, it will not work right out of the box without first implementing drivers adaptations in the Ardupilot firmware as they use new sensors.
  • Jon, I think that the X2.1 is pin compatible with Pixhawk, as the X2 was, so it should work right out of the box.
    I'm not sure, but, I think that's what they're doing.
  • Thank's Nick, I apreciate the common connectors too, easy to find everywere, easy to assemble, less fail, this fc work's with pixracer firm?
    I like this board for my next proyect :D
  • Looks great.
    Just one question. Looking at the time frame between release and Ardupilot working on your Pixracer, will your AUAV 2.1 flight controller work out of the box with Ardupilot?
  • Hi Cala,
    The holes are semiholes as the width is just 30mm while the holes grid standard is 30.5 x 30.5mm.
    As we plan to offer a housing and housing STL files, we'll design a tight mounting even with semiholes.
  • Nice product Philip.
    I'm curious why holes are only middle? isn't more difficult to fit?
    You have idea to provide the case too?
  • MR60
    Congrats Nick. Will be buying one !
  • Nice, looking forward to trying one. :)
    Yeah, the Pin header is a plus/minus thing.  They're big and bulky. But I do grow tired of trying to sort out cabling with other connector systems.
