The PX4 team is pleased to announce early availability of the PX4 autopilot platform, with hardware available immediately from 3D Robotics.
The platform is a low cost, modular, open hardware and software design targeting high-end research, hobby and industrial autopilot applications.
PX4 is an expandable, modular system comprising the PX4FMU Flight Management Unit (autopilot) and a number of optional interface modules.
The PX4FMU autopilot features include:
- 168Mhz ARM CortexM4F microcontroller with DSP and floating-point hardware acceleration.
- 1024KiB of flash memory, 192KiB of RAM.
- MEMS accelerometer and gyro, magnetometer and barometric pressure sensor.
- Flexible expansion bus and onboard power options.
Expansion modules available at release include:
- PX4IOAR This module interfaces PX4 to the AR.Drone motor controllers, allowing a complete quadrotor to be assembled using an AR.Drone frame and motors.
- PX4IO A flexible interface module with support for eight PWM servo outputs, relays, switched power and more.
As an open hardware design, third-party and DIY expansion modules can be easily developed for specific applications, and more PX4 modules are in development.
In addition to the versatile hardware platform, PX4 introduces a sophisticated, modular software environment built on top of a POSIX-like realtime operating system. The modular architecture and operating system support greatly simplify the process of experimenting with specific components of the system, as well as reducing the barriers to entry for new developers.
Adding support for new sensors, peripherals and expansion modules is straightforward due to standardized interface protocols between software components. Onboard microSD storage permits high-rate logging and data storage for custom applications. MAVLink protocol support provides direct integration with existing ground control systems including QGroundControl and the APM Mission Planner.
Pricing of the PX4 components reflects more than a year of careful development and a strong commitment from our manufacturing partner.
This release is targeted at early adopters and developers looking for a more capable platform than existing low-cost autopilots. With more than an order of magnitude more processing power and memory compared to popular 8-bit autopilot platforms, PX4 is exceptional value for money and provides substantial room for future growth.
For more information about the PX4 autopilot platform, visit the project website at http://pixhawk.ethz.ch/px4/
PX4 modules can be purchased from our manufacturing partner, 3DRobotics.
I think is a step in the right direction. I would like to see an autopilot that is "independent" from the platform. What I mean specifically is that an autopilot that can work on a car, boat, plane, heli, multicopter, because its outputting commands like forwards, backwards, left, right, rotate left, rotate right, climb, descend etc in order to achieve a desired result ie. move to position x,y. Yes the APM hardware can be REPROGRAMMED for different platforms, but an autopilot hardware+software that does not need to be reprogrammed and can be picked up and put into another craft would be cool.
And then a separate module that inteprets those navigation commands into craft specific, so for example the autopilot is told to move to position x,y,z it makes calculations and give the command to move forward. Which the craft specific module will then interpret, for a car it might be throttle on, for a quad it might be motor 2 increase power, for a helicopter it might be pitch forward.
I'm not sure if I have articulated this well, but I hope someone out there knows what I'm talking about. This PX4 seems to be doing, that, in terms of a autopilot system with a module specific for AR.Drone, and one for General RC.
Now let the crunching begin. Finally we have platform that can do multitasking and is easy expand. Congrats to ETH and others for it.
These look great, especially great if they usher-in an age where different open source UAV platforms (Ardu*, Pixhawk/NuttX, OpenPilot, ChibiOS, Paparazzi, ...) can be used on the same hardware. Exciting times!
Francis: this is aimed at a different market: research, universities and high-end performance. But ultimately, as Roberto says, we do plan to port the ArduCopter, ArduPlane, etc codebases to this hardware so people can have a choice of platforms to use, APM 2.x, 3.x (the ARM version), PX4 and others, such as Roberto's Multipilot32 and forthcoming VR Brain platform (which uses the same ARM chip as this PX4 board) that already runs ArduCopter.
Congratulation to 3DR team for his first platform based on ARM. And to ETH to his great work on RTOS and new approach to develop multi tasking application:)
I'm working with the Team to share my 2 years of experience on STM32 and Multipilot32 platform. The target of my work in the begin will be port Arducopter32 also on PX4 then using that as starting point and try to understand how improve the originally Arducopter firmware developed for 8 bit processor to new 32 bit platform.
I'm very happy to work at this project inside this great team.
If there are people that would join development on new Arm platform is welcome we need to doing a lot of work on it :)
I'm very interesting also to original PX4 RTOS and PX application that use all the resource available on 32 bit platform. Respect of Arducopter32 firmware the new PX4 RTOS and application is a lot different of standard arduino platform.
Best
Roberto
Looks great! I'm looking forward to getting ArduPlane on this.
Huge congrats to the PX4, ETH and 3DR teams for this launch, which has been the fruit of more than a year of work. Full details will come in the follow-on posts tomorrow and the rest of the week, but we think this is a game-changing platform, especially for advanced and experimental use. And although it may not be obvious from the photos in this post, but it's TINY!
apocolipse: Absolutely. Please check the product wiki for details, but this is a full pro-grade autopilot, designed as a platform for total autonomy.
6
7
8
9
10
of 10 Next
