Ionic thrusters use high voltage to ionize air and create an airflow, which in the right configuation can create thrust with no moving parts. I've tried an experiment like the above, and barely generated enough lift to raise a little balsa and aluminum foil off a table, but MIT says they can do far better.
From The Verge:
Stealth drones and other aircraft of the future could be powered by engines that don't have any moving parts, can't be detected by infrared, and are more efficient than what we have today. A new study by MIT researchers demonstrated all of these capacities and more for ionic thrusters and now at least one major aerospace company, Lockheed Martin, has said it's investigating the technology.
"I think UAVs would be the most likely initial application if [ionic thrusters] work," said the lead researcher in the study, MIT aerospace professor Steven Barrett, in an email to The Verge. Ionic thrusters for aircraft work by generating a high-voltage electrical field that strips electrons from air molecules, "ionizing" them and pushing them away behind an aircraft as ionic wind, to move the craft forward. Scientists and hobbyists have been tinkering with small, lightweight model planes using these kinds of propulsion systems since the 1960s. The technology uses no moving parts and is almost completely silent. It hasn't come to full-size planes, though, due to power concerns.
But scientists at MIT's department of aeronautics have built a working prototype (pictured above) that suggests the technology is more feasible than previously assumed, generating far more thrust (110 newtons per kilowatt of power) than a comparable jet engine (2 newtons per kilowatt). "You could imagine all sorts of military or security benefits to having a silent propulsion system with no infrared signature," said Steven Barrett, the lead author of the study published today in the journal Proceedings of the Royal Society. Indeed, Lockheed Martin is already expressing an interest, with an executive telling MIT News "there are still unanswered questions, but because they seem so efficient, it’s definitely worth investigating further."
Barrett told The Verge there are still major hurdles to overcome before aircraft ionic thrusters are able to be commercialized, namely a large enough power supply for their electrical field, and a way to retain efficiency at higher speeds. "At reasonable flight speeds [about 560 miles per hour] the efficiency does decrease, but still looks promising," he wrote in an email. Also, because it uses air molecules, "this kind of propulsion only works in an atmosphere," Barrett said. "It need not be the Earth's atmosphere though – for example, it could be useful in exploration of other planets where fully electric propulsion without moving parts may be beneficial."
Comment by Cliff-E on April 4, 2013 at 12:06pm
Ah, the chase (or holy grail) for matching specific impulse (velocity) to thrust (mass ejection).
The amount of energy currently required is likely higher than the thrust it can produce over time. But this would make a great secondary propulsion subsystem to counter-act wind displacement for multicopters and de-couple lifting needs from wind/position needs of the propulsion setup.
Comment by Anis Nielsen on April 5, 2013 at 5:44pm
I know on this forum dwells a uniquely old master specialist in this stuff .. http://jnaudin.free.fr/   sorry Jean-Louis ;) (hope he reads this and he will tell us much more about this :) )
Comment by Anis Nielsen on April 5, 2013 at 5:46pm
yes, im a big fan of Telsa and Leedskalnin :D
Comment by steve on April 7, 2013 at 6:13pm
Yes the coral castle in south florida. Been there a few times! http://coralcastle.com
Ed was a very interesting guy! http://coralcastle.com/whos-ed/
Unexplainable in today's technology.
And he had some unusually long fingers :)
Comment by Anis Nielsen on April 7, 2013 at 6:58pm
and a tiny frail body ! straaange :)
Comment by steve on April 8, 2013 at 4:23am
I have his book on magnetics. Very interesting. Have you seen it?
Comment by iangl on April 8, 2013 at 4:55am
Wasn't this a scam?
Comment by steve on April 8, 2013 at 5:20am
Was what a scam? Coral Castle? His book? Both definitely real and unexplainable in our current knowledge. His thoughts on magnetics is different than what we are taught also.
Comment by Jethro Hazelhurst on April 8, 2013 at 6:50am
Apperently every other page was left blank so that the reader could add his/her own thoughts! Pretty awesome!
Comment by Luc Maximilien on April 9, 2013 at 10:40am
Coral Castle, did not know that place but it is possible to create "stone" artifacts with the use of particular enzymes and sand. Nowadays there is a kind of 3D printer that create large architectural artifacts with that method.
Comment
