  • You might be interested in some of the open source work over at Public Labs
    http://publiclaboratory.org/tool/near-infrared-camera
    @MarcS
    And if a system is as robust as a tractor and usable by a farmer we can talk about precision farming. As long as you need an engineer/pilot to operate and prepare it, it will stay an academic use...
    This is a very good point, but it could also start as a service until the products are ready for push-button ease of use; given how fast things are changing I think we will get there in the next few years.
  • T3
    How high wing loading do you accept for hand launching?
    You see we cannot go far beyond some 100g/dm2. At this region you already have RC scale bombers.
    Small UAVs are inherently smaller than anything else than flies. As a consequence, they require shorter exposition times.
  • Chris,
    Substracting VIS from FS will not give nearly the same quality as an optical filter (tried and compared myself...). Mostly because you got much Vis remainig in the image. The calculation is just not accurate enough (and the efficiency of the sensors in IR too low). You just can´t trick physics :-(
    If you want a high sensitive chip in IR you have to go for professional stuff, you know the prices... It´s just not mainstream.
    If you want to do flying for remote sensing try to do it when the sun is in the zenith. You get the least shadows and least effects of BRDF´s...
  • T3
    Airspeed 45-55km/h
    Major source of blur is turbulence.
  • T3
    @Jonas, Lojze, excellent ideas. Will be pursuing in that direction. What worries me,having full spectrum is beneficial for having short exposition times (blur is an issue in smal UAV).
    I am wondering if subtracting VIS from FS will bring the same NIR quality I would get by using optical filters (that otherwise pass little light). This is an important issue that might affect flight plan and several mechanical details.
  • Hey Krzystof,
    I have a good idea. I am working in the wind power industry. I thought about the guys that are doing the wind prediction models for new wind farms. They need information for the surrounding area to make their wind prediction models. Here would probably 3D models from the surrounding terrain very useful.
    Maybe you can talk to the guys at www.cube-engineering.com they make the software for such calculations.
    Hope that helps with your crisis
    Best Regards
    SirSten
  • T3
    @Clark
    For me this is exactly ON topic :-)
    However, for detecting one inch nozzle track you need some half inch per pixel... Right?
  • Precision agriculture - excuse me for going a little off topic but this all ties in with the IR and what it us used for in our farming opperation.
    Some of the things we are doing with GPS:  at this time we are planting with 5 tractors/planters in the same field starting at 5 different locations all coming together with the row spacing being within 1 inch acuracy.  At the same time we are also controling seed rates and fertilizer being applied.  When we get done with each 125 acre field the amount of seed applied is within 1.5% and the fertilizer being within 0.7%.
    As these crops start to grow and we take the IR photos you can see spots where the seed may have been planted too deep or one row that had a clogged nozzle.  The percentages above were from some of the better fields, the field that are out of spec are the ones you can see variances in.  When planting 8000 acres of spuds, 9500 acres of corn, and 5500 acres of peas it pays to be precise and be able to analize the results.
    @ me - Like I said before, I'm not the camera guy and haven't dove into that one much yet, just going by what I was told.
  • @Krzysztof Bosak
    When I say real time obstacle avoidance I mean if the UAV is flying towards a tree it can gather the models in time to plot a course to evade it
  • Clark, can you confirm thar the ir mkosaic iR realy iR ?
    I think a real iR can show another color .
