I keep breaking my ArduCopter arches, so rather than order replacements, I just laser cut my own through Ponoko. I've uploaded the design, so you can do it too. Select 3mm clear acrylic, P1 size. It should cost $8.20 plus shipping for the four arches shown above. Note that these are laser cut, not CNC milled, so they don't have the notch on the side that fits snugly on the arms. But they work fine all the same.
Thanks to Sandro Benigno, you can also order a set of five replacement dome rings, as shown here:
All the other parts are in the ArduCopter repository, but need to be converted to SVG format to laser cut. If you see something you'd like to make, let me know and I'll convert and upload it to Ponoko. Most can be laser cut as easily as CNC milled, but in some cases you might need to do a little finishing work, like counter-sinking some holes. No biggie...
UPDATE:
I've added the Main Square:
And the Legs:
And the carrier board:
Thanks - i'm just trying to find some suitable CAD software to use as an outlet for my sudden bout of inspiration :)
sketchup is quite neat, but seems limited (cant join solids etc in the free one it seems). Does anyone have any suggestions for FOSS/Cheap CAD software?
Are you able to output that assembled model to something that can be loaded into Sketchup, or another free/FOSS 3D/CAD package
So, attached is the simplified motor mount I made in case this is useful for anyone. I'm using an ancient CNC mill and have to manually type in holes and arcs. I'm doing it in aluminum so there's no point in the led slot anyway.
Again, very sorry to have cast doubt on the excellent ArduCopter team who have created a brilliant product and done a great job of engaging with the community. You guys are the model of how an open source, open hardware project should be led.
http://code.google.com/p/ardupilot-mega/wiki/Tortoise
So, I have CAD'ded some Arducopter clone motor mounts. Should be finished tomorrow (in aluminum) and I'll upload cad files on Sunday. Pretty soon we will have a full set of community CAD files with which to make DIY replacement ArduCopter parts.
Fun working on this stuff, although I think it's still very strange that the ArduCopter folks have not yet released cad files. This is supposed to be an open hardware project, correct? Then why did Jani have the cad files removed without replacing them?
1
2
3
4
of 4 Next
