Hi all, please critique new look of the upcoming Ardupilot GCS. Functionality will be discussed elsewhere, so for now please provide constructive criticism for the "look and feel".
Log files will be great... I'm trying to set the gains for my plane and just can't get it right. Friend of mine has a Paparazzi and after the flight he can just plot the data to see what all the setting changes did... So Log files is a must! Thanks in advance. oh, btw, please keep in mind the small 8.9" screens. 1024x600 i think :)
Looks Great guys. My only suugestion would be to make sure that is EASY to read in bright sunlight. Maybee grab your lappy and go out and check its readability.
I was just going to mention the same thing as Pedro just did. Users have different needs and laptops have different screen resolutions, aspect ratios etc. I would suggest making each instrument a standalone applet. The applets can then communicate with a central node that contains flight data. That way you can open/close/resize and move around the instruments on the desktop as you want.
I have to agree with Dougs on some of his comments. I look at the panel a bit differently. I fly every day with the boeing 737 and I think you should maybe put in a panel that is a copy of a real plane as lots of people did research on it. That means that it's setup user friendly for a wide range of people.
I also read that some people want to become a uav operator later on and I think this would help for situational awareness (SA).
see the following picture:
So on top you see arm/hdg sel/vnav path This box displays the mode thrus //lat nav// vertical nav are in. *Maybe good for autopilot mode// way point
Left is speed tape with the selected speeds on top in magenta and the selected speed bug on the tape!
** handy to display how far speed is of from desired. At the bottom of the tape you could put ground speed GS
Bottom is the heading including the heading bug again.
*** Also good to for dispalying heading and the a bug for heading to Waypoint
Right is Altitude tape with vertical speed needle.
**** same as speeds tape handy for showing alt easy to read and can display selected altitude on top.
I know its a lot to program, but maybe you can steel some of its workings from any given flight sim website with free panels like Boeing 737 or Airbus.
Jasons idea is also good as a second tab next to the main view with maybe this ghost plane later.
Dougs values look perfect for me for alt in meter/feet but airpeeds I would say km/h or miles/h
@Cronselaar - there will be logging functionality ( actually two files are created - one is data log file with all telemetry defined data, and another is kml file...
Thanks to all who provided the input - keep'em coming...
I do like... Might i give one suggestion. Could we please write something in the GS to log the GPS co-ords and time stamp. That way there is no need for an extra GPS logger. The file could then later just be converted to kml or something. I like Jason's flash app.
Again Well done
Just an idea;)
Jason's GCS does look very nice !
Examples of some of the instrument displays can be found here:
http://www.diydrones.com/photo/albums/gcs-instruments
1
2
of 2 Next
