Hi all, please critique new look of the upcoming Ardupilot GCS. Functionality will be discussed elsewhere, so for now please provide constructive criticism for the "look and feel".
Here is what I use. If you want any of the graphics let me know. I built it in Flash and it's not really easy to setup. That's why I've never rolled it out, but I love using it. I am a total novice when it comes to traditional gauges, so I just made this up with what felt right.
I send out the Roll and Pitch sensor values as well as the IR_max values for debugging
In the center is a compass with a representative Waypoint.
You can see the output of the Servos in the bottom and right sides
The needle at the top is for outputting turn rate.
The lower half is for reading at a distance.
The GPS button shows the KML file.
There is a light next to the GPS button that blinks every time we get a GPS message.
The Google Maps section expands to show full screen.
How about a round attitude dial instead of a square box? And have the indicator stationery and the dial "globe move, like a real one? Could still do the ghost airplane deal, maybe?
The desired versus actual attitude isn't an IMU versus thermopile issue. We can provide the date in either case. It is just more accurate with an IMU. If a user is using an older firmware version and the ghost stayed fixed flat and level it might look just fine depending on its color. I was thinking a grey without too much contrast.
Altitude will be in meters. 0-200 is probably good.
Airspeed will be in meters/second, so 0-200 is too large. Perhaps 0-50. That is 111 mph or 180 kph which is probably adequate for 99% of users
I am not sure what everyone elses opinion is but do you need large dials displays. Why don't we just have numerical values just like the bottom right hand corner. That way we can display more information that is relevant, such and mission planning, waypoints enter etc.
- "..get a small area displaying the raw serial data stream.." - yes, that's in debug tab
- .."..ghost airplane" - yes it's possible. I was postponing this for later. Not all data is available in current ArduPilot code releases, so supporting (2.4), 2.5, and 2.5.1 might be tricky. But something I think we can work out between developers of 'thermopile" and "IMU" versions of the code in the (near) future.
-"..add a text box into the altitude, airspeed, and course dials..." will do
-"..What is the scale for the altitude and airspeed?.." whatever ArduPilot firmware provides :) . I think it's in meters and will add labels. Actually can you confirm units for the data you mentioned?
-"What will the map background be if internet is not available? - This version is based on Google Earth so you don't need an internet. However, if you visited location of the flight before ( with internet connection) ground images will be better..
"Is the yellow "thumbtack" a waypoint? " - No :) it's just a placemark in my local GE dile. However, I was thinking of adding wayoints as placemarks on the image ( and "ArduPilot IMU" version provides data suited for that - it'll be future improvement, once this comes out
Would it be possible to get a small area displaying the raw serial data stream. This would be useful for seeing messages during start-up and also for debugging. Maybe this is under the debug tab?
Maybe this is too wild an idea, but could we get a ghost airplane on the AHRS so that the ghost shows the desired attitude and the orange shows the actual. It will be easy to add the appropriate variables to the serial output stream.
Could you add a text box into the altitude, airspeed, and course dials that will give the numeric value. It is nice to be able to see the actual value as well as getting a quick look indication with a needle.
What will the map background be if internet is not available? Is the yellow "thumbtack" a waypoint?
Here is the full size version...
Thanks for the input !
1
2
of 2 Next
