LW20 LiDAR - half the size, twice the performance, infinitely better.
LightWare Optoelectronics is proud to share with you some preliminary data on their new miniature laser range finder modules, the LW20 and the SF20 OEM version. These modules will be available later this year and as part of our program of supporting the DIY market we will be offering the OEM module to individual customers as well. The prices will be announced at the time of the official launch ;).
Introduction:
The LW20 and SF20 miniature laser rangefinders offer high performance in a very small form factor. The LW20 is a sealed unit designed to withstand water splashes and dust whilst the SF20 is a lightweight, open frame unit ideal for OEM integration. Both units can measure more than 100 m in sunlit conditions and can measure down to almost zero distance. These professional grade sensors take up to 678 readings per second and provide distances to both the first and last signals with each measurement. The laser beam is encoded so that units can be aimed at the same target without interfering with each other, enabling multiple redundancy and allowing for many UAVs to operate safely in the same area. Serial or I2C communications ports provide a comprehensive suite of commands and the unit can be switched into power saving mode when not in use.
Features:
  • Very small size
  • Choose either a water and dust resistant unit (LW20) or a lightweight open frame module (SF20)
  • Weight of less than 10 g for the SF20
  • Water and dust resistant to IP67 for the LW20
  • Long measuring range beyond 100 m
  • High speed readings up to 678 per second
  • First and last signals measured with each reading
  • Encoded laser pulses for multiple systems
  • Serial or I2C interfaces compatible with 3.3 V or 5 V systems
  • Low power consumption with power saving mode
Applications:
  • Distance measurement
  • Laser altimeters for small or large UAVs
  • High reliability systems using redundant sensors
  • Scanning laser systems for mapping or obstacle sensing
Specifications:
Model number                                               LW20                  SF20
Maximum range [m / ft]                               110 / 360             110 / 360
Minimum range                                              ~ 0                      ~ 0
Maximum update rate [rps]                           678                      678
Resolution [cm]                                               1                          1
Accuracy [cm]                                                ±5                        ±5
Weight [g / oz]                                            20 / 0.7                 10 / 0.35
Dimensions [mm]                                      20 x 30 x 35          20 x 30 x 32
Housing material                                       Aluminium             open frame
IP rating                                                         IP67                       --
Operating temperature [C]                         -20 .. +60               -20 .. +60
Power supply [V]                                        5 ± 0.5                   5 ± 0.5
Operating / standby current [mA]              170 / 45                  170 / 45
Notes:
1. Maximum range is measured against a stationary, large white target in full sunlight at 84 readings per second
2. Maximum operating temperature depends on suitable airflow or heat sink
LightWare Optoelectronics (Pty) Ltd  is an ISO9001 certified manufacturer of laser products for UAVs, industrial, aircraft and other applications. The attached information is subject to change without notice.
Comment by Brandon Robinson on October 5, 2016 at 11:52am
Seconded. I want like to order as soon as it's available!
Great work Lightware team!
Comment by Laser Developer on October 6, 2016 at 6:27am
I appreciate the enthusiastic offers to part with your money as soon as possible ;). Now that my part in this development is coming to an end, a team of hard working people is getting the new product into production and I wouldn't want to put any undue pressure on them by promising a delivery date or firm price. Keep an eye on our website and in the media for updates.
Comment by Paul Meier on October 6, 2016 at 6:31am
don´t mind those commercial people, please put undue pressure on  ´em :)
Comment by Emin Bu on November 1, 2016 at 4:06pm
Any news....?c'mon,at least you can tell us in which quarter of the year will be..please.
Comment by Laser Developer on November 1, 2016 at 11:27pm
Ok, ok... Samples are already being sent to selected clients and everything is on order to start pre-production during November. Some of the first units will go to the dev's for integration into the ArduPilot project. The official launch will be at the end of January.
We are gearing up for production of the LW20, which is the enclosed IP67 unit, and the open frame SF20 that is for OEM customers but will also be available to the DIY community. In addition, Tracy (our design genius) is preparing information on how to make your own scanning LiDAR using off-the-shelf components and some 3D printed parts. I've got one sitting on my desk that uses the SF20 module and a high quality servo. The '20 laser module is light enough to allow for a reciprocating scanning pattern and the whole scanner is about the size of a regular matchbox, weighing just 33g!
Comment by Emin Bu on November 2, 2016 at 10:24am
Thank You,that is great news....eagerly waiting for Tracy's project...
Comment by Gary McCray on November 2, 2016 at 12:39pm
Hi LD,
Really happy to hear about it, looks like you will have a real winner here.
The SF20 is just what I am looking for and I will definitely want 2 as soon as I can get them.
Would very much like to see your scan results with your tiny servo scanner.
Best,
Gary
Comment by Wanabigaplane on November 2, 2016 at 2:03pm
Just what I need for my servo driven scanner, but some easily fixed hardware problem remain - how do you mount it on anything? Odd shape. No lugs or screw holes. Which way does the lead come out that facilitates mounting? Is there any means of cable strain relief?
Jack.
Comment by Laser Developer on November 2, 2016 at 10:27pm
@Gary - thanks Gary, data will start coming out soon. So far it looks awesome ;).
@Wanabigaplane - the legs are just the stand for bench top testing, not part of the product. You can direct mount the servo if you have a suitable flat spot on the airframe or else Tracy is planning to offer a bunch of different brackets that you can print yourself. She'll also provide pictures to show how best to manage cable routing.
Expanding on the scanning theme for a moment, we'll also be offering a smart communications "hub" that manages the servo and laser controls, collects the scanned data and performs real-time analysis to locate obstacles or store maps. This hub will offload the processing from the flight controller, making it easier to develop drivers in the FC, as well as providing multiple interfaces so that a collision sensing scanner and up to two laser altimeters can be run from the same FC port.
Comment by Emin Bu on November 27, 2016 at 3:38am
Any news?
Comment
