LW20 LiDAR - half the size, twice the performance, infinitely better.
LightWare Optoelectronics is proud to share with you some preliminary data on their new miniature laser range finder modules, the LW20 and the SF20 OEM version. These modules will be available later this year and as part of our program of supporting the DIY market we will be offering the OEM module to individual customers as well. The prices will be announced at the time of the official launch ;).
Introduction:
The LW20 and SF20 miniature laser rangefinders offer high performance in a very small form factor. The LW20 is a sealed unit designed to withstand water splashes and dust whilst the SF20 is a lightweight, open frame unit ideal for OEM integration. Both units can measure more than 100 m in sunlit conditions and can measure down to almost zero distance. These professional grade sensors take up to 678 readings per second and provide distances to both the first and last signals with each measurement. The laser beam is encoded so that units can be aimed at the same target without interfering with each other, enabling multiple redundancy and allowing for many UAVs to operate safely in the same area. Serial or I2C communications ports provide a comprehensive suite of commands and the unit can be switched into power saving mode when not in use.
Features:
  • Very small size
  • Choose either a water and dust resistant unit (LW20) or a lightweight open frame module (SF20)
  • Weight of less than 10 g for the SF20
  • Water and dust resistant to IP67 for the LW20
  • Long measuring range beyond 100 m
  • High speed readings up to 678 per second
  • First and last signals measured with each reading
  • Encoded laser pulses for multiple systems
  • Serial or I2C interfaces compatible with 3.3 V or 5 V systems
  • Low power consumption with power saving mode
Applications:
  • Distance measurement
  • Laser altimeters for small or large UAVs
  • High reliability systems using redundant sensors
  • Scanning laser systems for mapping or obstacle sensing
Specifications:
Model number                                               LW20                  SF20
Maximum range [m / ft]                               110 / 360             110 / 360
Minimum range                                              ~ 0                      ~ 0
Maximum update rate [rps]                           678                      678
Resolution [cm]                                               1                          1
Accuracy [cm]                                                ±5                        ±5
Weight [g / oz]                                            20 / 0.7                 10 / 0.35
Dimensions [mm]                                      20 x 30 x 35          20 x 30 x 32
Housing material                                       Aluminium             open frame
IP rating                                                         IP67                       --
Operating temperature [C]                         -20 .. +60               -20 .. +60
Power supply [V]                                        5 ± 0.5                   5 ± 0.5
Operating / standby current [mA]              170 / 45                  170 / 45
Notes:
1. Maximum range is measured against a stationary, large white target in full sunlight at 84 readings per second
2. Maximum operating temperature depends on suitable airflow or heat sink
LightWare Optoelectronics (Pty) Ltd  is an ISO9001 certified manufacturer of laser products for UAVs, industrial, aircraft and other applications. The attached information is subject to change without notice.
Comment by Laser Developer on November 28, 2016 at 12:49am
@Emin Bu - This project is progressing well and we have started sending test units to selected people. In the picture below you can see a few of the interesting features of LW20. The whole product is sealed with no exposed electronics. Cable entry is through a waterproof gland and the aluminum housing forms an RF shield. These pre-production models weigh 18g without the cables.
Comment by Bernardo on December 7, 2016 at 2:48am
:) great tech specs! following up the final version and release date ;)
Comment by Laser Developer on December 7, 2016 at 10:25pm
@Bernardo - Final hardware completed and some comms software still to finalize. Official launch end Jan 2017. Keep watching this space :).
Comment by Fnoop on December 20, 2016 at 10:58am
Is it possible to give a rough ballpark on price?
Comment by Laser Developer on December 20, 2016 at 10:17pm
@Fnoop - I can't say for certain until the official launch but right now it looks like the one-off retail price will be around the price of our entry level SF02 and SF10/A products.
Comment by Laser Developer on January 18, 2017 at 2:24am
Website is here:- LW20
Comment by Valdur Kaldvee on January 18, 2017 at 3:07am
It is good news. Will SF20 also be available shortly?
Comment by Laser Developer on January 18, 2017 at 3:10am
@Valdur - Yes, the SF20 is also available for order but the website needs to be updated. I'll post here as soon as it shows up ;).
Comment by Pascal P. on January 18, 2017 at 8:38am
@Laser Developer : I can  not go to your link
Comment by Laser Developer on January 18, 2017 at 10:36pm
@Pascal P: It's a new website so you might need to refresh your browser a few times.
Comment
