Mapping with E382 and DroneMapper
3689469051?profile=original
I just wanted to share a mapping mission I ran last week with the E382 from Event 38 (my company) and processed with DroneMapper.com.
The reason these results are somewhat noteworthy is the amount of time it took to make this. I pulled up to the flying field, setup the plane in maybe 5 or 6 minutes. I hand launched the plane, flew around manually for exactly 5 minutes, taking 110 pictures in that time. Brought it in for a quick landing in some bushes then I packed up and went home. At home I uploaded the images straight to DroneMapper without even reviewing them. A few hours later, DM came back with really awesome results. All of this took just a few minutes of my time not counting the drive to and from the field.
My setup on the E382 is as follows:
- Skywalker 168cm Airframe
- APM 2.0 with ArduPlane 2.4
- 3DR Telemetry Radios 915MHz
- Canon Powershot SX230 HS with CHDK
The camera is really what made this so quick.. with built in GPS all the images are geotagged automatically as they're taken. This mission was actually done to see if it could keep a GPS lock for the entire flight which it did. Having the images geotagged and processing them with DroneMapper returns files that can be analyzed (as in the image above) for things like the elevation profile of any path, the length of a path, the area of a field and so on. There are nice tutorials on how to get started with that in the DroneMapper FAQ.
3689468999?profile=originalMeasuring the length of a trail
3689468939?profile=originalMeasuring the area of low lying vegetation
3689469058?profile=original
Extracting the coordinates of a point of interest
  • Denis Deasy: good find this PENTAX !  http://www.dpreview.com/products/pentax/compacts/pentax_optiowg2gps
    manual focus...  continuous drive 1fps ? not shure if this can shoot for ever ? the remote control will allow many trigering gadget to work with ! THANKS
    Pentax Optio WG-2 GPS: Digital Photography Review
    Expert news, reviews and videos of the latest digital cameras, lenses, accessories, and phones. Get answers to your questions in our photography foru…
  • @Jeff Great work - I intend using Dronemapper for aerial photo processing, this confirms it as best current option. Was considering using APM to trigger camera at specific waypoints, but not sure if that command is currently implemented (I know the code is written...), so have been looking for a rugged camera (Irish conditions make that a necessity !), with high pixel count, decent lens, GPS and intervalometer...the Pentax Optio WG-2 GPS is the only one I could find that has that feature spec, maybe worth trying. The new Olympus TG-1 iHS looks pretty impressive, but I don't think it's got an intervalometer - I agree it's a mystery as to why most cameras don't have this feature, seems an obvious one to me.
  • Thanks! Yes, that's just from a shot which was improperly exposed. I haven't experimented much with any fixes but I've found that normal cameras have trouble taking pictures of water when the water makes up most of the frame. One thing I need to do in the future at least is to lock focus at infinity which I think will take care of some of the blurry pictures near the water's edge.
  • Very nice results, congrats!
    In the middle of your mosaic, there is a spot which is brighter than the rest of the image. Do you know why that is?
    How does dronemapper deal with color ballancing?
  • @nuno yes there's always room for improvement!
    @John the altitude actually varied a LOT on this flight from as low as 50m when the camera started taking pics during take off to the end when I got up to about 130m AGL above the high terrain.
    @Richard Thanks. No there's no stabilization on the camera itself, the small angles that you'll get from flying can be dealt with by DroneMapper, it expects that. What problems are you having with the images?
  • Nice, what altitude were you flying at?
  • oh congrat about Dronemapper site and many thanks for the GeoTag Time sync hint !
  • Well done, but, yes one thing to improve is the camera to use, more megapixel, better work , and most of the times faster work.
    The samsung cameras, are fine, i don't know if it's possible to use the chdk.
  • Hi manu, yes it's possible even without GPS cameras. The Mission planner has a tool to geotag images from the APM logs based on image timestamps. The trick is getting the right time offset to match up GPS time with your camera's timestamp. An easy way to help yourself in that process is to set your camera's clock to GPS time. The only place I know that has any more info on it is the Dronemapper FAQ under the section titled "Ardu Geotag Hints & Time Sync Information"
  • Well done Jeff, that's looking good!
    Wondering if you can acheive the same quick result from the other Canon (A2200), which doesn't include a GPS? Maybe with the addition of the APM log in a way or another?
