Having already got my OpenLRS set up to send Mavlink data back from my plane (using the gitsly OpenLRS branch), the next step was to get Mavlink data displayed on my Taranis.
The Taranis need inverted levels to serial pin in the module bay so I build an inverter from the schematic here.
I saw this topic a while back: MAVLink data displayed on OpenTX (9X/9XR/etc) radio screen via OpenLRS, plus telemetry pass-thru to PC and assumed this would also work on Taranis. No such luck! There is no EXT=MAVLINK option for Taranis in the configurator.
However I managed to get the OpenTX build environment set up on Ubuntu following the instructions here without too many difficulties. Then is was a matter of redirecting the telemetry bytes into the existing mavlink code, and displaying the Mavlink settings and telemetry screens rather than the Frsky ones. I was quite surprised when it all worked however! The Mavlink serial is also available from the serial connector on the OpenLRS module so that can be connected to a PC or Android device.
In the original 9X Mavlink firmware it was not possible to select which telemetry protocol to use except by reflashing. I need a mixture of S.Port and Mavlink telemetry depending on which plane I'm flying so that didn't suit me too well. I added an option in the model menu telemetry options to use Mavlink rather than S.Port or Dbus, so each model can have it's Mavlink or Frsky telemetry received and displayed :) .
I also thought it would be useful to have the radio read the flight modes as they are receiver over Mavlink, this wasn't too hard to incorporate either. I created sound files for each Arduplane mode and added code to play them on receipt of a new mode.
Something else I would like do is to copy the Mavlink data into the normal Frsky variables so that they can be used in the normal way, i.e. read out, used in Lua scripts and for vario sounds etc.. It's on the to-do list.
Hopefully this will be useful to some people out there, I will post the code after I get a chance to clean it up slightly as it is a bit of a hack! For now the binary and sound files are here (they need to be in the SOUNDS/en folder):
https://drive.google.com/folderview?id=0B4xnWmfKh4FrVFl4YlU1Zm9nQU0&usp=sharing
Cheers,
Sam
Cheers, Sam
Well, I got it compiled, and it seems to work well. Here are the options used:
make PCB=TARANIS PCBREV=REVPLUS EXT=FRSKY-MAVLINK HELI=YES LUA=YES USB=MASSSTORAGE
Sam, let me know if you want me to send you the file, maybe you could store it along with the other files you got.
-Håvard
I'm using ULRS 2.0 beta, have you tried range testing with that? It seems to handle the distance and data transfer better.
I'll install Ubuntu and give it a go, there's a first time for everything. I don't have to make any changes to the code, just use the correct options for the make command, right?
-Håvard
I think it was probably USB = JOYSTICK. I'll recompile if I get round to it but your best bet might be to download the code from my github and make any changes, it's pretty straightforward to build (and a good reason to set up a Ubuntu partition!).
Cheers
Sam
Hi Sam,
I'm using your firmware, but I can't enter bootloader mode to use the USB for OpenTX Companion.
Was the firmware compiled with option USB = JOYSTICK? If so, could you please compile another hex-file with option USB = MASSSTORAGE instead?
(As far as I know Linux is needed for compiling, I only use Windows...)
-Håvard
Does this require any hardware mods to the radio?
Hi Sam,
I'm new to long range and telemetry with taranis.
At the moment I'm using this solution to get a solide telemetry but this is only for the x8r.
http://diydrones.com/forum/topics/amp-to-frsky-x8r-sport-converter
I still don't know what hardware I should buy best. Thinking about
http://www.hobbiesfly.com/transmitter-receiver/Transmitters/dtf-uhf...
and the
http://www.hobbiesfly.com/transmitter-receiver/Receivers/brotronics...
because of the sbus.
Would your solution work with this hardware as well? I haven't bought it yet so I'm absolutly open to what I have to buy.
I would realy have a solution like the teensy one but on a UHF device.
Sorry for my lack of knowledge, but the topic is quite complex.
Thans for your help
Any binaries out there for the gitsly branch?
Hi Sam,
amazing work! Have you ever tried to commit your work to the upstream OpenTX project? That way your changes would be maintained by the upstream project and your changes would "stay alive" in newer revisions of OpenTX without having to adjust them constantly by yourself.
Holger
1
2
of 2 Next
