I finally received my Raspberry Pi Zero, just in time to get into the DIY challenge of building a smart drone with the Pi Zero and APM under 100$. I called this project: MINI-Zee
How this can be done?
Well first of all, thanks to Victor and the team at Erle Robotics for releasing the plans and software of their PXFmini. This is a real inspiration for building my own board, because all the parts are available at a cheap price and are relatively easy to assemble and interconnect using through-hole breadboard, providing you are very experienced with this type of build. Thanks to Mirko as well, for having introduced a real DIY autopilot project that allows us to experiment with a fully working and well supported BeagleBone based ArduPilot Cape called the BBBMINI.
Bill of Material (US$ - Transport & taxes excl.):
Raspberry Pi Zero 5.
MPU 9250 (SPI 9 dof IMU) 8.
MS 5611 (SPI Baro) 9.
PCA 9685 (16 channel PWM Servo Driver) 5.
3.3 v. regulator 1.
BEC 3 amps 3.
Breadboard, Resistors, Connectors, Misc. 7.
AutoPilot: 38.
HobbyKing Spec FPV250 V2 Quad Copter
ARF Combo Kit - Mini Sized FPV 60.
Total: 98.
*This is Banggood price; I had an ADAFRUIT –PWM on hand, and I really recommend going with ADAFRUIT, because of all the effort they put on making a great tutorial and drivers for this product. Note: Just like Erle , the USB WIFI, GPS and the Radio Control are excluded.
Building:
A) Hardest part: Get a RASPBERRY PI ZERO (Where is my Zero site)
B) Hardware - See BOM
C) Board Schematics : Erle pxfmini
D) Board Software: Erle pxfmini
E) LOAD LATEST Raspbian-Jessie
Disable serial Login (Allow GPS on serial Port)
Enable , I2C, SPI , Serial
Disable Console = Auto Log on a shell
F) LOAD RT-PREEMPT
http://www.frank-durr.de/?p=203
Load Test Result: TEST: T: 0 ( 1136) P:80 I:500 C: 100000 Min: 16 Act: 31 Avg: 32 Max: 157
G) MAKE ArduCopter
Special MINI-ZEE release:
1) The MPU 9250 is mounted on the Z-Axis, so we need to change :
CONFIG_HAL_BOARD_SUBTYPE == HAL_BOARD_SUBTYPE_LINUX_PXFMINI
, _default_rotation(ROTATION_YAW_270) = to ROTATION_NONE
2) The PCA9585 has no external clock, and the ESC are connected to ports 1-2-3-4, so we need to change:
static RCOutput_PCA9685 rcoutDriver(PCA9685_PRIMARY_ADDRESS, true, 3, RPI_GPIO_27); -to-
static RCOutput_PCA9685 rcoutDriver(PCA9685_PRIMARY_ADDRESS, false, 0, RPI_GPIO_27);
H) Fly the MINI-ZEE == Add these to /etc/rc.local
#wait till network is up and DHCP assigned address
while ! ifconfig | grep 192.168.2. >> /home/pi/bootlog; do
echo “no network, waiting…” >> /home/pi/bootlog
sleep 5
done
echo “Starting ArduCopter” >> /home/pi/bootlog
sudo /home/pi/ardupilot/ArduCopter/ArduCopter.elf -A udp:192.168.gcu-address:14550 -B /dev/ttyAMA0 > /home/pi/startup_log &
exit 0
I) FIRST FLY LOG:
Thanks to the damping platform, the vibration level is within specs. Video is available for anyone interested..;-)
Conclusion:
This project took about 20 hours to complete. As you can see, I really enjoyed doing some hardcore DIY to demonstrate that it is still possible to build your own flight controller from a Linux Based system. I do not recommend to try this as a first project, but if you are interested, get a BBBMINI, this is the best introduction to DIY and if you want to fly a Raspberry Pi Zero, it is much easier to buy a PXFMINI.
Here is release 2 of the Mini_ZEE
I finally received the RPI Zero with Camera and decided to upgrade the motors as well.
Still need some adjustments since the camera induces some noise on the GPS and now the Wifi Dongle need its own power.
understood.
thanks for taking the time to answer
regards, Matic
Thank You
There are 2 reasons:
A) This build is based on the pxfmini that has a lot of similarities with the Navio, and both are using the PCA9685 for PWM.
B) There is no consensus in the community as if the RPI can generate stable PWM using its own resources (see some discussion here: PIGPIO ) . So instead of going on the unknown I decided to stick with 2 generation of working autopilots and adapt the pxfmini code for my particular build.
hello,
Great work
I have one question tho, why do you need PCA9685?
thanks
Hello Victor,
You can use the main repository, https://github.com/ArduPilot/ardupilot
Hello Patrick.
D) Board Software: Erle pxfmini, this is "https://github.com/erlerobot/ardupilot", it is right?. Thank
Regards
Hello Patrick, Thank you!
Regards
Hello Radioelf
Once I had modified the sensor files for my particular setup;
ardupilot/libraries/AP_InertialSensor/AP_InertialSensor_MPU9250.cpp = for the IMU
ardupilot/libraries/AP_HAL_Linux/HAL_Linux_Class.cpp = For the PWM
Lauched the MAKE process (no cross compile , just build straight from the PiZero):
cd ~/ardupilot/ArduCopter
make pxfmini
Regards
Hi Patrick, you can comment a little more: G) MAKE ArduCopter. (requirements)
Regards
Hi.
Very interesting ... I'm starting a similar project, right now i am with PCB design with Kicad.
8
9
10
11
12
of 12 Next
