I finally received my Raspberry Pi Zero, just in time to get into the DIY challenge of building a smart drone with the Pi Zero and APM under 100$. I called this project: MINI-Zee
How this can be done?
Well first of all, thanks to Victor and the team at Erle Robotics for releasing the plans and software of their PXFmini. This is a real inspiration for building my own board, because all the parts are available at a cheap price and are relatively easy to assemble and interconnect using through-hole breadboard, providing you are very experienced with this type of build. Thanks to Mirko as well, for having introduced a real DIY autopilot project that allows us to experiment with a fully working and well supported BeagleBone based ArduPilot Cape called the BBBMINI.
Bill of Material (US$ - Transport & taxes excl.):
Raspberry Pi Zero 5.
MPU 9250 (SPI 9 dof IMU) 8.
MS 5611 (SPI Baro) 9.
PCA 9685 (16 channel PWM Servo Driver) 5.
3.3 v. regulator 1.
BEC 3 amps 3.
Breadboard, Resistors, Connectors, Misc. 7.
AutoPilot: 38.
HobbyKing Spec FPV250 V2 Quad Copter
ARF Combo Kit - Mini Sized FPV 60.
Total: 98.
*This is Banggood price; I had an ADAFRUIT –PWM on hand, and I really recommend going with ADAFRUIT, because of all the effort they put on making a great tutorial and drivers for this product. Note: Just like Erle , the USB WIFI, GPS and the Radio Control are excluded.
Building:
A) Hardest part: Get a RASPBERRY PI ZERO (Where is my Zero site)
B) Hardware - See BOM
C) Board Schematics : Erle pxfmini
D) Board Software: Erle pxfmini
E) LOAD LATEST Raspbian-Jessie
Disable serial Login (Allow GPS on serial Port)
Enable , I2C, SPI , Serial
Disable Console = Auto Log on a shell
F) LOAD RT-PREEMPT
http://www.frank-durr.de/?p=203
Load Test Result: TEST: T: 0 ( 1136) P:80 I:500 C: 100000 Min: 16 Act: 31 Avg: 32 Max: 157
G) MAKE ArduCopter
Special MINI-ZEE release:
1) The MPU 9250 is mounted on the Z-Axis, so we need to change :
CONFIG_HAL_BOARD_SUBTYPE == HAL_BOARD_SUBTYPE_LINUX_PXFMINI
, _default_rotation(ROTATION_YAW_270) = to ROTATION_NONE
2) The PCA9585 has no external clock, and the ESC are connected to ports 1-2-3-4, so we need to change:
static RCOutput_PCA9685 rcoutDriver(PCA9685_PRIMARY_ADDRESS, true, 3, RPI_GPIO_27); -to-
static RCOutput_PCA9685 rcoutDriver(PCA9685_PRIMARY_ADDRESS, false, 0, RPI_GPIO_27);
H) Fly the MINI-ZEE == Add these to /etc/rc.local
#wait till network is up and DHCP assigned address
while ! ifconfig | grep 192.168.2. >> /home/pi/bootlog; do
echo “no network, waiting…” >> /home/pi/bootlog
sleep 5
done
echo “Starting ArduCopter” >> /home/pi/bootlog
sudo /home/pi/ardupilot/ArduCopter/ArduCopter.elf -A udp:192.168.gcu-address:14550 -B /dev/ttyAMA0 > /home/pi/startup_log &
exit 0
I) FIRST FLY LOG:
Thanks to the damping platform, the vibration level is within specs. Video is available for anyone interested..;-)
Conclusion:
This project took about 20 hours to complete. As you can see, I really enjoyed doing some hardcore DIY to demonstrate that it is still possible to build your own flight controller from a Linux Based system. I do not recommend to try this as a first project, but if you are interested, get a BBBMINI, this is the best introduction to DIY and if you want to fly a Raspberry Pi Zero, it is much easier to buy a PXFMINI.
I mean befinitif
Hello Alex
This is on the quad, and with hostapd the Mini Zee IS the Access Point, so my laptop attach to the quad.
Yes I am actually testing with different types of antennas - clover leaf /patch / others.
No these would not work with WIFI Broadcast, as I can see the best would be using the TPLINK on 2,4 ghz === so getting back to conflicting frequency. I know that benetiv made a clever device with a cpld so we could split the spread spectrum. I left a message on the wifibroadcast to benetiv to check if he was still active, so far no answer...
@patrick Are you using this on your quad or on the receiving end? Would two of those dongels work well for wifibroadcast? Also would using a different kind of antenna like a patch/yagi increase the range of the things?
Just an update on conflicting 2,4 Ghz between WIFI and Radio-Control.
,I switched WIFI to an EDIMAX AC600 running as an Access Point on 5 GHZ with the use of HostApd and loading this DRIVER.
Here is a picture of the modified USB Dongle with the micro USB adapter cable soldered directly + a 5volts BEC + a RP-SMA adapter cable to attach the 5GHZ antenna.
So far the tests are good, I'ts flying smoothly and the video is fluid at 640x480 x 20fps up to 500 Meter.
Yes,
This can be implemented as a service and now that the latest Raspian releases are getting into Ubutu service model this and be an option. But considering this is an experimental branch, I prefer keeping it as simple as possible and loading with rc.local offers lot of flexibility and has the advantage of an easy ''kill'' within sudo top command
Hi. After getting ArduCopter.elf, you must create a script and service to run with startup raspberry, run_copter.sh and systemctl enable copter.service? Thank
Regards
Well, at a second though, this was not a good example, take a at those Flight Controlers that are on my wish list :-)
http://www.banggood.com/TAULABS-SPARKY2_0-Flight-Controller-with-ST...
But at the price, it is getting quite close to a full blown PixRacer:
http://www.banggood.com/Pixracer-Autopilot-Xracer-V1_0-Flight-Contr...
@Alex, yes hackerboards is on my morning reading list, but this morning I was out early to continue my test on camera, and it still need lots of tweeking, but we'll get there :-)
That board is a nice weather station, but I would not fly a weather station (LOL) : The bmp180 & lsm303 are the old generation of sensors. The ms5611 and the mpu9250 are , at the moment, top of the line sensors for flight controller. Just look in the NAZE world, and all the new high performance FC are using these devices , take a look: http://seriouslypro.com/spracingf3evo
@patrick I'm back with another suggestion. I was on linuxgizmos.com, now hackerboards, and noticed this pi zero hat http://hackerboards.com/raspberry-pi-zero-sized-hat-has-four-sensor...
It has the bmp180 which i know to be supported by ardupilot and the lsm303d gyro as welll. not sure about the lsm303d but with a few hats and a pi zero you may have a solderless solution except for soldering the pins on the pca9685 servo hat.
Well, just a word of caution from an old DIYer ; Proceed by steps and do not put too much unknowns on a prototype build. Make it work first, and the you can step into the unknown, personally I have so many projects going on (10 builds actually) that I try to keep the OS & the Code vanilla...
5
6
7
8
9
of 12 Next
