I finally received my Raspberry Pi Zero,  just in time to get into the DIY challenge of building a smart drone with the Pi Zero and APM under 100$. I called this project: MINI-Zee
3689684951?profile=original
How this can be done?
Well first of all, thanks to Victor and the team at Erle Robotics for releasing the plans and software of their PXFmini.  This is a real inspiration for building my own board, because all the parts are available at a cheap price and are relatively easy to assemble and interconnect using through-hole breadboard, providing you are very experienced with this type of build.  Thanks to Mirko as well, for having introduced a real DIY autopilot project that allows us to experiment with a fully working and well supported BeagleBone  based  ArduPilot  Cape called the BBBMINI.
3689684972?profile=original
Bill of Material (US$ - Transport & taxes excl.):
Raspberry Pi Zero                                      5.
MPU 9250 (SPI 9 dof IMU)                         8.
MS 5611 (SPI Baro)                                   9.
PCA 9685 (16 channel PWM Servo Driver)  5.
3.3 v. regulator                                          1.
BEC 3 amps                                             3.
Breadboard, Resistors, Connectors, Misc.   7.
                                               AutoPilot:  38.
HobbyKing Spec FPV250 V2 Quad Copter
ARF Combo Kit - Mini Sized FPV         60.
                                                     Total:  98.
*This is Banggood price; I had an ADAFRUIT –PWM on hand, and I really recommend going with ADAFRUIT, because of all the effort  they put on making a great tutorial and drivers for this product. Note: Just like Erle , the USB WIFI, GPS and the Radio Control are excluded.
Building:
A) Hardest part: Get a  RASPBERRY PI ZERO (Where is my Zero site)
B) Hardware - See BOM
C) Board Schematics : Erle pxfmini
D) Board Software: Erle pxfmini
E) LOAD LATEST Raspbian-Jessie
Disable serial Login (Allow GPS on serial Port)
Enable , I2C, SPI , Serial
Disable Console = Auto Log on a shell
F) LOAD RT-PREEMPT
http://www.frank-durr.de/?p=203
Load Test Result: TEST: T: 0 ( 1136) P:80 I:500 C: 100000 Min: 16 Act: 31 Avg: 32 Max: 157
G) MAKE ArduCopter
Special MINI-ZEE release:
1) The MPU 9250 is mounted on the Z-Axis, so we need to change :
CONFIG_HAL_BOARD_SUBTYPE == HAL_BOARD_SUBTYPE_LINUX_PXFMINI
, _default_rotation(ROTATION_YAW_270)  = to ROTATION_NONE
2) The PCA9585 has no external clock, and the ESC are connected to ports 1-2-3-4, so we need to change:
static RCOutput_PCA9685 rcoutDriver(PCA9685_PRIMARY_ADDRESS, true, 3, RPI_GPIO_27);      -to-
static RCOutput_PCA9685 rcoutDriver(PCA9685_PRIMARY_ADDRESS, false, 0, RPI_GPIO_27);
H) Fly the MINI-ZEE == Add these to /etc/rc.local
#wait till network is up and DHCP assigned address
while ! ifconfig | grep 192.168.2. >> /home/pi/bootlog; do
echo “no network, waiting…” >> /home/pi/bootlog
sleep 5
done
echo “Starting ArduCopter” >> /home/pi/bootlog
sudo /home/pi/ardupilot/ArduCopter/ArduCopter.elf -A udp:192.168.gcu-address:14550  -B /dev/ttyAMA0 > /home/pi/startup_log &
exit 0
I) FIRST FLY LOG:
3689684898?profile=original
Thanks to the damping platform, the vibration level is within specs. Video is available for anyone interested..;-)
Conclusion:
This project took about 20 hours to complete. As you can see, I really enjoyed  doing some hardcore DIY to demonstrate that it is still possible to build your own flight controller from a Linux Based system.  I do not recommend to try this as a first project, but if you are interested, get a BBBMINI, this is the best introduction to DIY  and if you want to fly a Raspberry Pi Zero, it is much  easier to buy a PXFMINI.
  • Yes, also Mavpixel. Both over USB
  • Are you using a 3dr telemetry module
  • I will have to check it out when I get a chance later on tonight or tomorrow. I have a ready to fly quads power module that fits perfectly on my vdq210. I'll hack the cable apart to get it going.
  • Hi
    two VCC wires and two GND wires directly to PCB. Any 5v and any GND will do.
    https://goo.gl/photos/FSUsC88AabYjmked7
    New photo by Matic Jovanovič
  • I've got another question. I received your pcbs after ordering from oshpark. I'm getting a brown out powering the way I was with my receiver. How did you connect the power wires from the apm power module to the board you made?
  • sure. how this helps.
    https://goo.gl/photos/UQJfKFmfhwwF3Njs5
  • @Mattic Jovanovic are you able to post pictures of both the front and the back of the pcb you had made. I have an idea of what i need to do. I also wanted to see what parts you populated on the board minus the mpu9250 and ms5611.
  • matic jovanovic, how about those files so i can take a look?
  • from what i have seen a double sided pcb should be able to be produced from home as well.
