Mission Planner upgrade -- get it for latest firmware
3689424737?profile=originalDue to the recent shift from a Subversion to a Git repository, you'll need to use the latest versions of the Mission Planner to ensure that you'll be able to get the latest ArduPlane and ArduCopter firmware. Versions from 1.0.67 up will pull from the correct Git repository.
Google Code has currently got a file download glitch, which they're working on. So in the meantime, I've put the latest version of the Mission Planner (1.0.68) in a public DropBox folder here.
UPDATE: The regular Google Code repository is now working again.
Once Google has got the download issue fixed, the Mission Planner will be available in the download section as usual.
  • Any clues when the AP_Mount library will be used by Arducopter ?
    I left a comment in SVN about it, but now that we moved to GIT my guess is that the developers did not see it.
  • I see that the latest version has two IP Ports settings for using the ArduPilot in HIL mode. What is the correct setting in X-Plane? As far as I could see the Wiki manual still shows the instructions for a single Port settings.
  • I have it working great. All movements are dialed-in exact with a spirit level and done just using mission planner. Spare channel left over for camera trigger. As you say, it is very easy - once you know how. great job Jason. Vid, to follow.
  • So it is, I must spend more time here.
    Denny, instructions on changing servo direction are in the manual.
  • Thanks, thats great. I see we have stabilized camera outputs on two channels. Is it possible to have stick inputs to go with this and also a way to reverse the servo rotation.  I could not find that in the set-up?
    Update: Google has found the bug (something about "double escaping") and will have it fixed by the end of the day.
