Moscow State University. Hardware stability test. Video "as is".Without any postprocessing (no deshaker, no color correction, etc.) Camera: Canon 5D Mark III Lens: Canon EF 24 mm F/2.8 IS USM
If u talk about Z15 - yep - but it NOT amateur solution at all
German BL gimball hardware prised more than 800$ for heavy model cos assembled inter alia with high cost sensors for extrmly quality stabilisation
It's NOT amateur solution too.
Flight behavior unclear but Cinestar6 frame HW itself well known as very good quality, stable and powerfull, but very high prised. t.e. http://quadcopters.co.uk/cinestar-6-frame-kit-91-p.asp£1,184.95 chinese clon more chiper ofcource =)
I'm not found any technical specifications info abot flight controller used in this copter.
It's filmed with HIGH cost complex for making semiprofessional cinema - Cinestar frame from freeflysystems.com Modified as they write w BL gimbaL hw from kamkop.de|
Why would they that publishhereit is not clear Only reson boast offinancial resources =)
others can learn, Robert, but not from this! Like last time and the time before that, it's all very secret squirrel. Glory to vis.asta and the motherland! Glasnost be damned!
the gimbal is much cheaper as the zenmuse one.
Flight behavior unclear but Cinestar6 frame HW itself well known as very good quality, stable and powerfull, but very high prised. t.e. http://quadcopters.co.uk/cinestar-6-frame-kit-91-p.asp £1,184.95
but still, the flight controller is extremely nice.
did you notice the flight behaviour?
the killer app/hw for 3dr.
LOL! NOT and NOT again
Why would they that publish here it is not clear
Only reson boast of financial resources =)
Really nice heavy duty brushless gimbal mount Vis,
And really great video results, brushless gimbals do work way better than the old servo ones.
at the end of this video you can see how the device looks :)
@Andrew Rabbitt : "glasnost & perestroyka" led to disaster in my country ;-)
@Aleksandr Akulov: there are plans :). but need to explore around ...
I don't think to have ever seen such a good scene on a movie.
no i run against the language barrier.
not killing the building ;-)
but your hw/sw combination is extremely nice and well tuned.
others can learn.
