The new design of the Mugin UAV 3M is out.
It's a huge UAV platform with 300 mm wingspan. The platform caters to larger UAS projects such as universities or commercial projects. It's really not a beginner platform.
The platform is available here: Mugin UAV 3m vIII
It comes with or without engine/prop.
Twin Motor
Type: Two-stroke piston valve petrol aircraft engine
Displacement: 55cc(27.2ccx2)
Bore x Stroke: 34mm×30mm
Carburettor: Walbro(Diaphragm & Butterfly Valve)
Max. Output: 5.6ps/7600rpm
RPM Range: 1600-7800rpm
Weight: About 1780g(Engine+muffler+CDI)
Ignition power: Auto advanced CDI(DC 4.8 Volts , 4 cell NiCad or NiMh battery)
Fuel mixture(Ratio of gasoline and oil): 25-40 : 1
Propeller: 20X12-23X8 two-blade prop( suggest to use 22x8 prop)
20 kg! But why?
The V-tail will soon be posted in the Web as well.
Hey Soviet, you cant see my picture ? its a V-tail option.
@Hein If you are unsure then I think you definitely need to consider whether they have the right one for your project.
Not many need a big bird like this.
I wonder if they will offer it with a V-Tail option? Other than that, this thing is a great deal considering it's size and included goodies and apparent building quality.
@hook...Do you know the average endurance with the 2 1500cc tanks? what is the average max payload weight?
wing are fiberglass? carbone fiber? or covered balsa strucutre?
@Hooks,
Yes and only with dead stick else para gets chopped up by prop :(. Any Ideas/suggestion for para?
I think a Para landing should only be a failsafe option, not a standard way to land the bird.
