Hi all. Been lurking around here and the RCGroups site for a long time and finally got around to actually starting a multi-copter build. I built my first Sig Cadet way back in the day, but got caught up doing other things for about 20 years. Back to RC now and loving it. And thanks to all in and around these projects that are making the community tick. Open Source only works if you have kick ass people like Chris and a big team of supporters. Nice job!
The MCopter is built on an RC Carbon frame from RC Hobby Helicopter (Thanks John!) and will be running 4 Hacker 20-22L's with 10 x 3.8 props. Once I get the four motor version running we may bump it to eight in coax config to have more margin. I have ArduPiratesNG on the APM right now so I can test the two axis camera mount with the GoPro Hero. Once we get closer to the first test flight I'll decide which code base we fly.
Here's a few pics from Flickr
UPDATE: 2/16/10
Finally got the first version built and went for a maiden. I am flying the latest ArduPirates code, but I did not do any PID tuning as I was tired of waiting and wanted to see how close it was stock settings. This version is still a bit under-powered so I am going to switch from 10x3.8 to 10x4.7 SF props to see if it will help a bit. I just want to get a feel for the thing before I strap four more motors on. I'll spend much more time PID tuning before the next flight.
I added a few more pics to the Flickr set and am still waiting for the youtube video to show up...
So what I found weird with the GoPro was that in my loft it didn't seem to like the low light so much but when I took it out and flew it at dusk it seemed to do ok. It seemed darker at dusk though than it did in my living room, but it might have also had something to do the way it was balancing you can change to balance on center of view or it can compensate for overall light hitting the sensor, I think I had it in center view when I had it out at dusk, I'll test this weekend and post some vids.
Coby- What about the frame did you not like? I have a few different designs that are pretty similar to what droidworks has out and was just curious what you had to say before I go cut up my CF sheets and be all Ugh!! That dosen't work like I expected.
Cheers Coby!
@davey have not pushed the gopro too hard yet, but i would say for a single very small sensor at that price not to expect much for low light. i'll put that on the test plan as it's a very valid question. my biggest complaint about the gopro is usability of the menus. keep the manual handy for sure. if they could squeeze a few more lines out of that lcd they might be able to print full words instead of cryptic abbreviations. but for the price/size/weight it's pretty capable. my long term plan is to swap it out for something in the 4/3's sensor category but need more time to find the right rig. I was thinking Panasonic's DMC-GF2 but do not know if it can do simultaneous video out and record - anyone happen to know? I have not really dug that deep yet.
@taylor this mount does not allow use of the case anyway but i do have plans for a bit of cnc work with the gopro case to help keep it water resistant with external connectors. need to weatherproof the copter before it's a real concern for the payload. also in the works.
Guys, Can you get AV out of the camera and record in HD at the same time?
Whats the low light performance like?
Thanks!
I've never seen that website before, the frames are stunning!
Looking down the back of the couch........
1
2
of 2 Next
