My new octocopter frame
This is the new folding frame Project I am working on.
3689393875?profile=original
Can anyone tell me if it´s possible to control the eight counter rotating motors with ACM.
    Actually ACM has full support for Tri, Quad and Hexa's already.
    For coaxial setups you should have separate control for all 8 motors due lower motors needs to run with slower and optimized speed or you waste a lot of mAh's for fighting against the wind.
    Using 8 PWM outputs from APM is a bit tricky due hardware issues. OUT5-6 cannot be used to Fast PWM due hardware issues on microprosessor.
    I2C is also a bit tricky to use due if one I2C fais they all fail. This is due I2C bus.
    We are working on UART based ESC's that are safer to use in 8+ configurations. No real ETA for those.
    I think eight is supported by the ArduPirates code.
    ACM will start with quad and tri support
  • @ Ike: The developmet is made with SolidWorks.
    This was also my first thought but of the coax config I will los the Yaw effect.
  • If you are runnint 8 motors in a standard coaxial configuration you should be able to run it using y leads to split 4 channels into 8.
    In a coax config, two motors receive exactly the same signal.
