    In the code we'll release this weekend, the diagonal mode of the sensor is supported.
  • Thanks Bryan I will give that a go.
  • Regarding the IR sensor, you can rotate it 180 deg to avoid the excess wire hanging out by a little code modification. Under the IR tab:
    Find the lines return constrain((int)(((infrared0-511)*90)/max_ir), -60,60);
    return -constrain((int)(((infrared1-511)*90)/max_ir), -60,60);
    Change the +/- values before "constrain" to
    return -constrain((int)(((infrared0-511)*90)/max_ir), -60,60);
    return constrain((int)(((infrared1-511)*90)/max_ir), -60,60);
  • I'll also be using a radian once my sensors arrive, so keep us posted. Doesn't the xy sensor need to be in a + position not X. or are you waiting for 2.1 ?
  • Thanks Chris just waiting for some nice weather cant wait to get it up there will keep you all informed on my progress.
    Thanks.
    Looking good! Let us know how the tweaking of the PID gains goes. We've never tried ArduPilot on that plane.
