Hi Everyone.
I would like to share my experience using navio+ as flight controller.
At first when discovered navio i was a little skeptic if this board could really be as good as it looks. I read all the documentation over at Emlid.com and i finally decides to order one for testing.
When i got my hands on this board, i immediately fell in love. Nice layout and solid connectors and at last, this board fits beautifully on top of the RPI.
Then i installed Real Time Kernel for RPI and Ardupilot. Installation went painless, just following theirs instruction line by line.
An important note! You dont need to be a linux geek to get this going. Everyone is able to put this togheter.
After the installation is complete, you can launch anyone of the supported vehicles:
- APMrover2
- ArduPlane
- ArduCopter-quad
- ArduCopter-tri
- ArduCopter-hexa
- ArduCopter-y6
- ArduCopter-octa
- ArduCopter-octa-quad
- ArduCopter-heli
- ArduCopter-single
Typical ArduPilot start command:
sudo ArduPlane -A udp:<GCS_DYNDNS>:14550
Then just use Mission Planner and connect using UDP option.
So after several days with bad and ruff wheatear, the sun was finally shining and i immediately packed up for maden flight.
Today i was flying for 60min using Navio+ as flight controller and 4G for video and telemetry.
I have one word; Awesome.
My aircraft Skua FPV was rock solid after running Autotune function.
My setup:
- Navio +
- RPI 2
- 4G USB Cellular adapter
- Logitech C920 webcam with gstreamer
- Logitech Gamepad F710
- GCS ( My Laptop with Mission Planner )
- Airframe Skua FPV
This brilliant board keeps everything in one piece, specially when using 4G / 3G cellular. There is no need for extra converters as i used before with APM or pixhawk in conjunction with RPI.
I simply connect the 4G usb to RPI2 and start the Ardupilot with UDP telemetry option. Simple as that.
Guys at Emlid currently works to get the Odroid-C1 support for Navio+ .
APM autopilot port for Navio+ currently works with:
- Raspberry Pi Model A
- Raspberry Pi Model B
- Raspberry Pi Model A+
- Raspberry Pi Model B+
- Raspberry Pi 2 Model B
I will post an "HowTo configure RPI, Navio+ and Cellular network" at my website: UAVmatrix.com
So for those of you that are skeptic, try it. you won’t be disappointed.
Emlid gives you great and fast support at theirs community section.
Regards
Bernt Christian Egeland
Mine is in the mail as well. I have the RPI 2 all setup with 3G working. I have fixed IP address 3G connections so I don't need the dynamic DNS. I might add the video later.
I am running my programs in screens so I can see what is going on by switching to and from the running screens. I am not sure if the AuduPlane code runs OK in screens yet but I will post when I get it flying in my Penguin.
Looking good! Glad to hear the install went well because I've got one coming in the mail (so does our EKF master Paul Riseborough).
I think the main thing we need for large scale adoption is a better method of updating the flight code on the boards (i.e. get the MP's Install Firmware screen working) but we have a vague plan to do that.
@Bernt
a little bit about typo on headline. replace "communucation" with "communication". then would be better.
So essentially as long as you have 4g in sight you have unlimited range and unlimited FPV? Is that correct?
