Hi everyone! I'm very happy to announce our new u-blox based GPS board. The development teams and 3D Robotics have been working on this GPS unit for some time, and we have seen very good results on ArduPlane, ArduCopter and ArduRover. The Sparkfun AVC and the Quadcopter Rodeo were excellent opportunities to observe this GPS in action, and it helped Team Overhead win first place at AVC.
The device is pretty straight-forward. It has active circuitry for the ceramic patch antenna, rechargeable backup battery for warm starts, and I2C EEPROM for configuration storage. The units will ship pre-configured for ArduPilot Mega use, and the configuration file is available in the repository if needed.
Features and Specifications:
- ublox LEA-6H module
- 5Hz max. update rate, configured for 4Hz for APM
- 25 x 25 x 4 mm ceramic patch antenna
- LNA and SAW filter
- rechargeable 3V lithium backup battery
- low noise 3.3V regulator
- I2C EEPROM for configuration storage
- power and fix indicator LEDs
- ArduPilot Mega compatible 6-pin JST connector
- exposed RX, TX, 5V and GND pads
- 38 x 38 x 8.5 mm total size
- 16.8 g weight
It's on sale now, price is $75.99 USD. It starts shipping on Monday, July 9th.
Design files and links to the board's main component data sheets can be found in the product listing.
We look forward to hearing your feedback!
Tridge did some work to make it so the APM will automatically configure the gps to use the right settings at start-up. Hopefully that'll make it nice and easy for people to get working. We shall see when they start arriving in people's mailboxes I guess.
http://opensat.cc/wiki/balloon:gps - LEA-6H ceiling is reported as 50,000m
am I correct that the LEA-6H is "HAB-compatible"?
Adam: I'm not following. It works fine with the APM 2 hardware (yes, it comes with a cable). Or did you mean the version of APM 2 with the built-in MTK GPS?
Adam: Both the ArduPlane and ArduCopter code will auto-recognize it. No setup required.
Interesting, put my request in one. For those that want the meat:
Acquisition down to 1 s, –147 dBm coldstart sensitivity and 5 Hz update rate
I just realize the Mikrokopters's are using this module in their latest offerings. And this with their latest firmware release is a world of a difference on position hold.
Now I know the Mediatek can run better (-165dBm, acq <1s), but LIRC the update rate was lower w/the APM/3DR fw (correct?). Could a big ground plane adapter on the MTK even things up?
