Guys , should we have some thing like this( caption contest) going? Any way , diy AP cannot get any better than this , High lights/salient features.
>4 point landing gear, self retraction, auto flaps, self healing too
> no GPS required ,"tail wagging" is automatic (most of the times)
>RTL Works in air and on Land too!!
>Find me is built in. You will never loose it, and if you do , it will come back eventually or high pitch sounder( built-in) will alert you of it location
> Pan and tilt does not require additional channels
> FAA and other regulations do not apply to this airframe operations( conditions apply)
> No spl software or programmers/interface required. Unlimited memory, etc etc
> Voice activation and command language
> Rx is interference proof
> Can win any contest any day any time
What do you think guys?
@Paul , your AP or code has issues , time to change the model
@ Earl . it is towed to high altitude and released, design is based on world war 2 glider( I am guessing)
- Slavers in the car during the trip to the flying field.
- Loses covering material on expensive furniture that inevitably clogs the vacum cleaner.
- Basically neurotic and unpredictable.
1. You need to debug the program for urinating issue.
2. The walking 3 times a day is intentional for now ( see issue 1)
3.
(especially if it happens to be the mailman> Ohh , that is optional function , it is called sentry mode and can work while in hover too. It is a premium option for some mil application coming under "Right of self preservation"
@ Michael , yes it can be factory upgraded to be hairless and so no brush is required. Take your pick here
@ Michal . It should not cause of concern if you follow standard regulations " No Smoking any were in refueling Area "
Thanks guys for good inputs , keep it coming. cheers.
BTW : The one issue u missed and still hasn't been resolved ( as per company spokes person) is 2 Way telemetry is not available.
-when changing diet you get a new jet propulsion
- the AP needs to go for a walk three times a day
- the AP may urinate inopportunely somewhere in your shop
- Find me function sometimes goes berzerk and switches on if someone knocks at your door
(especially if it happens to be the mailman)
- Energy source is expensive
