New! APM Planner 1.0
3689411504?profile=original
Over the past couple of weeks I have been busy reworking my original APM Mission Planner. Together with my partner/designer Samantha Nelson we have focused on improving the APM Planner’s interface, ideally resulting in a more intuitive user experience.
Below are a couple screenshots of the new APM Planner!
3689411466?profile=original
3689411394?profile=original
APM Planner Version 1.0.0 can be downloaded here -
https://code.google.com/p/ardupilot-mega/downloads/list
  • Function has been greatly improved,Good!
  • 不错
    Good
  • @ Michael   It would be nice if the zoom = to at least HK_CSG's.  Same goggle map right?  Also what about a basic map that could be loaded for at the flying field that does not need internet connection.  very basic map just something to use as a reference. ?
  • ok thanks,  i think i am working it all out slowly.
    p.s very impressed with your hardware aswell :)
    Adrian: the Mission Planner was just released this morning. We'll have the wiki updated by this evening.
  • WOW!
    I am new to ardupilot (just turned up on Friday) the planner looks great but im having a bit of trouble matching the wiki to the new software, will there be an update to the wiki for the new softwear.
    Yes it should work on a netbook. ive tested at 1024x600
    Looks great! very nice... thanks (and yes, try to zoom more, even if it blur out.
    @ Peter - I'll look at adding different units (ie feet..)
    @ Mees Vincent - APM Planner caches all loaded content, and has always done. So long as you load it before you leave to go flying, you should be fine.
    @ Amilcar - Please make sure you have the latest build. I removed reference to Microsoft.DirectX.DirectInput, just before I posted the zip file.
    @ Ritchie - I will add some filters to load the older NAV_ versions, as well as the new shortened versions.
    @ Russell - I will have a look at giving better zoom, but like ritchie said, the quality of the picture wont get any better, it will just start blurring out.
    @ ALL - Thanks for the positive comments!
    amilcar: you can use the CLI and Qgroundcontrol instead. They both work on Linux.
