New Easy Star Accessory - Electronics Chassis
3689420649?profile=originalHello Everyone
The Easy Star Electronics Chassis is being added to the DIY Drones store today. This accessory allows you to mount your APM/Oilpan, GPS Module (Mediatek or uBlox), Differential Pressure Breakout, Receiver, and pan/tilt camera mount on your Easy Star. The chassis provides access to the CLI switch, USB connector, and the Reset button as well as providing a clear view of the ‘ABC’ LED’s on the Oilpan at all times. It is also compatible with two GPS modules; the uBlox module can be mounted to the vertical plate near the back and the Mediatek gps module fits perfectly on the shelf above that (or you could use some double sided tape and stick any module anywhere). Most receivers should fit on the top base and can easily route wires to the APM beneath. The APM is mounted on the bottom and once it is mounted there is no reason to take it out as everything is accessible, but if the need arises, the bottom plate is designed to pop out more easily than the rest of the chassis so there is no need to take it all apart.
The chassis will be sold in two configurations, one with the pan/tilt camera mount (which you might recognize from Jeff’s post earlier in the week) and one without. Hope you like it and happy flying.
http://h9z6z.kmn9z.servertrust.com/Easy_Star_Electronics_Chassis_No_Pan_Tilt_p/es-chassis.htm
-Alan
3689420549?profile=original
ps. we have flown this with the camera configuration as shown and having the camera off center doesn’t seem to pose a problem. Mounting it this way allows for a less obstructed view, as well as the ability to look down :).
  • hi guys is there any news on the bixler chassis yet please
    Easy Star Chassis is back in stock today! we are waiting on some materials but we hope to have a Bixler chassis sometime next week :)
    OK. So, your foam isn't conductive. In fact it isn't antistatic ones.
    It's just low-charging (will not create harmful charges by friction... just it).
    Here goes a picture of the one I were talking about (the conductive one):
    3692264520?profile=original
    Peter, sounds not recommended. Press the foam between the two multimeter probes and you will see lower resistance values. We should expect weird things happening due to vibrations and inertial forces.
  • I *think* antistatic bags are conductive. Thats why they work. They hold the same potential on all pins so there is no potential difference in the case of a static shock.
    Be careful so that you are not using conductive foam for the middle layer. Conductive foam is common as packaging material. http://conductivefoam.net/
    Sorry for the typos. iPhone on a plane
    Your preference. If you are I always like screwing it down with some dampened under the apm. However lately I've been flying quads with double sided tape under the apm and it works just fine. So it is up to you. The hole pattern is provided bit you don't need to use it.
    Simon, looks great!
  • Chassis for Bixler
    Here's my version which I put together for my Bixler. Material is 2.3mm ply (~3/32"). The APM tray is a little deeper and longer to fit my mounting configuration. If anyone is interested I can make the CAD file or pdf version available.
    3692261186?profile=original3692261273?profile=original3692261201?profile=original
