New, Higher Performance NDVI Converted Cameras
3689571054?profile=original
Late last year we released our first version NDVI converted cameras using Schott BG3 filters. Using those filters we were able to generate pseudo NDVI images with a single camera, building off the work of the Public Lab project. After working with faculty at the University of Boston and the MEASA Lab at KSU, we determined that we weren’t quite getting the best results possible with the BG3 filter glass. Unfortunately, no off the shelf filter glass seemed to do exactly what we needed, block out red light and allow NIR light to pass instead. Luckily, we were able to find a manufacturer to help us build a custom filter to our specifications, and the results are looking really good! Below are two images, the first taken by a camera with BG3 filter glass and the second taken by a camera with the new custom glass, the difference is clear.
BG3 Filter GlassSchott BG3 NDVI
Custom Filter GlassCustomFilter
Aside from higher overall values, there is more differentiation and detail in the leaves and a larger difference compared to the non-organic background material. This is especially important for this type of camera. Since these are uncalibrated, pseudo NDVI images, what is really needed most is high differentiation so that comparisons can be made between the majority of plants and potential problem areas. The higher detail available now makes it possible to catch unhealthy plants sooner.
Custom Filter Transmittance vs WavelengthFilter Transmittance
The new filters will be priced at $39.99 for the filter alone (8.9×7.9mm, fits SX260 and S100 at least, potentially others) and$499.90 for a ready to go converted SX260 with CHDK. It’s a little cold to be doing any crop surveys here in the Northeastern US right now, I actually ended up killing those two plants after taking them outside for just a few seconds! We’ll be out and collecting imagery as soon as anything starts growing and I’ll post updates as they become available.
  • This is their spectral graph without a notch filter:
    3701695199?profile=original
    This is with the notch filter:
    3701695500?profile=original
    Doesn't look like a massive amount of difference except the price of importing it to the UK makes the maxmax more expensive.
  • James, it is definitely a different filter as ours was custom made and I'm sure theirs was as well. There is a slight difference you can see visually between the two images (on theirs, vegetation looks more orange) but I'm not sure exactly what the transmittance values on their filter are. I don't have a side by side unfortunately.
  • Great work, it would be interesting to see how this compares to the maxmax conversion. I would have thought they were very similar although the filter may be different as it would also likely be a custom build.
    Do you have any direct comparisons with maxmax?
  • Great! I'll be working on speeding them up and making them work with any picture format/size.
  • Nice, I've been following your work. Yesterday I received the new filters, they look really different from the old blue ones. I am  looking foward to test it. Also I will try Fiji, Agpixel and any other options to generate ndvi and biomass.
    Would be really nice if you share your scripts. Once again congratulations for this development and research. For sure this will be a great and cheap option for agricultural remote sensing.
  • @Photofly The filter can be used for any camera that it fits into.. so far we've only verified the Canon SX260 and S100. More point and shoots probably will work, but it's impossible to tell until you open it up and verify it physically.
    @Arnaldo Thanks! I actually use my own scripts to generate NDVI because Fiji wasn't giving me the scale and I was also sometimes suspicious about what was really going on inside. Plus I wanted the ability to mess with other experimental indices more easily. I have a bunch of AWS credit so I might put it up so others can use it easily as well.
  • Wich software you are using to do the NDVI scale?
    Best Regards and great Job!
  • @Hugues I think the glass for an NEX would be at least double but I'm not sure how much of the filter cost comes from glass area and how much comes from the cutting into pieces.. would have to get a new quote.
    @Jesus True the NEX takes a much better picture than the SX260 but the IR-only interface is really clunky for UAS integration, I think. I prefer something with a cable like the NX1000, personally.
    The A5000 would probably be pretty similar to the NEX and NX1000
  • Que buen aporte Jeff. Muchas Gracias!!
  • Guys, would be nice if we start thinking on sony A5000 ndvi conversion and trigger method. This camera will be perfect for uav mapping.
