The New FPV APM Kopter
In the foreground, the bumblebee
in the background the Kamkop with the GoPro 3D system
The new FPV Kopter
made vor 10" Props
to use GoPro or a smal FPV camera
NTM Prop Drive Series 28-30A 750kv / 140w
Motors:NTM Prop Drive Series 28-30A 750kv / 140w
ESC:
TURNIGY Plush 30amp Speed Controller
Accu:
2200mA
now I'm still working to find the correct PID parameters
for a stable and no wobbling flight i have to set the P parameter unter 1
than i have not enough sensitivity on my RC
maybe someone has experience with such a small Kopter with relatively large engines!
or someone could rewrite the code for me ?
Peter
the bumblebee is self-made
I follow the system no longer
(the prototypes and molds are for sale)
it a video on
https://www.youtube.com/watch?v=AgJEmOJRtr0&feature=related
On my FPV Mini Quad i have now
P on 2
I on 0
It flies very well
but
the sensitivity of my remote control is to low
how can I change it ?
test the acro mode?
Peter
Yes, The D term has been renamed P-Rate
Is your bumblebee a kit or a DIY? I'd love to see some more pics if it's DIY,
@Ryan with D do you mean P-rate?
As far as I know there is no D term... :)
@Peter
I have been playing with the P-rate and raising it (or lowering it) does make a difference on how the quad reacts even on stabilize mode.
2mm GFK
ca. 800g
Peter
hello
What material is this made out off?
How heavy is this quad when it is fully loaded?
steven
hello Guntars,
the Spacers are from Conrad-Elektronic in Germany !
Peter
Where do you buy spacers (black cylinders between arms)?
This huge overlapping is like having unbalanced propellers.
A propeller increases airflow velocity/decreases pressure and the below propeller has to cope with 2 different airflows on each blades.
Ok, it is... design exploration !
Thanks !
i will try the D Parameter !
the Quad is OK ! no Problems with the overlapping !
i fly it also good with the HK System
