I'm using RFM22B radio modules and ATMEGA328P chips on Rx and Tx.
Rx modules including 8 channel servo ports and RS232 for telemetry uplink
Tx modules including PPM-Input for analog servo control and RS232 for Computer based controls and Telemetry downlink.
System range will be around 4-5km.
Firmware Upgradeable over RS232.
Ground tests was unbelievable, it's working around 500 meters into the city (after 20+ concrete building)
I will share the flight test results, sources and schematics soon.
If you have any idea about design and inputs, please share with me before 4th generation's production..
Thanks for reading
Melih
No, my 50mw video transmitter's range was around 1km. This is why I flight behind a car and folded phone line antenna for reducing OpenFARC output. I guess it's range more than 5km. Today We tested it's control capabilities. We will test the range in this week.
The platform was a disposable Depron plane, our FC480 camera and FTX50 50mW 2.4ghz video transmitter.
After first flight, we played with a funjet for testing high speed responses
Results:
- It's working from 1 km away without any problem when transmitter behind the car's metal body (antenna was a 17cm phone cable)
- Refresh rate and latency was similar with a 2.4ghz Futaba tx/rx
- We finished 3 hours flight and ground test without any problem
Next week i will order 4th generation PCBs for first release of OpenFARC system.
Thanks for reading
Here is the project's home page: http://blog.flytron.com/category/openfarc-project
@Ivan,
Dont worry, i'm working about simple design :)
We are in a public holiday for 10 days, then i will send the design to PCB producer.
My $0.02: Forget about additional features, buttons, etc. Make it opensource, simple, cheap, and release it fast.
- it will be compact
- serial ppm output
- receiver side analog rssi
- tx-rx rssi over telemetry
- a button (better than my jumper solution)
- a sma socket pad for commercial antennas
- 10 channel output if it possible
- I2C slave port
- shell type pinouts for external telemetry or autopilot modules
- failsafe
- servo commands over rx telemetry port for direct autopilot controls
This is the list of features. I'm not sure about I can do that all features my self. This is an opensource platform and I hope other atmega users will help me to finish it.
I'm waiting for new ideas from you
Cheers
Melih
so both could be connected, something like a shell,
just take a look at ardupilot mega and the arduimu, :D
dont forget a PPM output conector too my friend
does it has fail safe? how its done the link? i see no buttons in the receiver,
maybe you could make it ready to connect it to simpleOSD and see RSSI or dBm,wich would be better as far as i know, because RSSI is not stable at all
1
2
3
of 3 Next
