New IMU offered by Sparkfun here. I think this board has some great potential that could lead to some all singing, all dancing Arduino-native IMU.The fact that this IMU is built around the ATMege 168 makes me think that it could be re-flashed to become some sort of "ArduIMU" board, and even run a ported version of the "Premerlani-Bizard robust direction cosine matrix estimator / MatrixNav firmware" as per this suggestion.Perhaps this board could be partnered with the ArduPilot, the IMU doing its thing, and the ArduPilot providing GPS info and servo driving?Anyone got any opinions for or against this? Or even better, technical reasons why this a) won't work, or b) is an awesome idea! :DSimon
ATmega 168:
16k flash
512 bytes eeprom
1k sram
i think it would be a challenge to fit kalman filter,a descant smoothing filter and centripetal acceleration comp plus serial com into this.also a good imu incorporates some gps data so it would also need to intake that. seems a bit skinny if you ask me.
Wouldn't it be simpler to put the GPS on the IMU board itself, have it process the data locally and simply return the unified position and velocity vectors to the ArduPilot? If all the ArduPilot is doing with GPS data is parsing it and passing it to the IMU that seems like a waste of processor cycles...
16k flash
512 bytes eeprom
1k sram
termopiles give a 2º accuracity and 1º the oones from copilot II
Our thoughts exactly ;-) Think "IMU shield"
1
2
of 2 Next
