New long range module for Turnigy 9X 9Ch Transmitter or other JR Radios.
3689398669?profile=originalLong range JR UHF radio system 265 USD
The new UHF RC system is based on Ham band and neighbouring band from 400mhz-470mhz, with the frequency hopping technology and frequency sweeping technology, you never need to worry about losing control of your precious plane.
Have short range trouble? this LRS has a range beyond your imagination. with a bad antenna, you may still get 20km range in the air, and with a super good 1/2 wave length one, you can even get 60km in the air.
3689398624?profile=originalParameters:
RF output:1000mw-2200mw
Power comsumption: 300-600mA
Range: 20-60km in the air
Failsafe: Yes
High and low power selection: 1000mw or 2000mw output
Highspeed control: yes
Transmitter parameters:
Hardware frequency Range 400MHz to 470MHz
Frequency stability :2.5ppm
Output low-pass Filter :NONE
Band 1
Start frequency:415Mhz
Step frequency:480Khz
Channel :70
Band 2
Start frequency:433Mhz
Step frequency:30Khz
Channel :70
Output Power : 30DB Peak / 33DB Peak
Rate : 40Hz/66Hz
RF interface impedance :50 Ohm
Supply Voltage :  8.4V to 16V
Reverse battery protection:NONE
Logic Voltage :3-12V
Current :
330mA/520mA (@50 Ohm load,12V Supply Voltage)
250mA/440mA (@No-load,12V Supply Voltage)
950mA/1.6A (@RF Short circuit,12V Supply Voltage)
Temperature:50 to 70 Degrees Celsius
Receiver parameter:
Frequency Range 400MHz to 470MHz
Sensitivity :     -112 DBM @0.1EBR(40Hz Refresh rate)
                  -111 DBM @0.1EBR(50Hz Refresh rate)
                  -110 DBM @0.1EBR(66Hz Refresh rate)
                  -108 DBM @0.1EBR(90Hz Refresh rate)
                  -104 DBM @0.1EBR(125Hz Refresh rate)
                  -104 DBM @0.1EBR(166Hz Refresh rate)
                  -101 DBM @0.1EBR(250Hz Refresh rate)
F/S turn on condition : >0.99EBR
Antenna gain : 2.15DBM
Step frequency :10kHz
Bandpass filter:Chip integration
Out-of-band rejection  :No specific data
It can work with video and audio transmitter which frequency less than 300Mhz or higher than 500Mhz .
Refresh rate :40Hz50Hz66Hz90Hz125Hz166Hz250Hz
Hopping rate :40Hz50Hz66Hz90Hz125Hz166Hz250Hz
Hopping cycle:13Hz16Hz22Hz30Hz41Hz 55Hz 83Hz
Recover time :77mS62mS45mS33mS24mS 18mS 12mS
Response Time : 4mS to 25mS
PWM Output accuracy :0.5uS step ERROR<20PPM
PWM Output range : 0.5mS-2.5mS
PWM output cycle :55Hz  @Normal mode
                  192Hz @Fast mode
PPM Output accuracy :0.5uS step ERROR<20PPM
PPM Output range : 0.5mS-2.5mS Each channel
PPM output cycle :50Hz@Normal mode & 1mS to 2mS Output
                   42Hz to 50Hz  @Normal mode & 0.5mS to 2.5mS Output
                         50Hz to 83Hz  @Fast mode   & 1mS to 2mS Output
                        42Hz to 125Hz @Fast mode   & 0.5mS to 2.5mS Output
PPM sync pulse width:4mS to 16mS  Automatic adjust @Normal mode
                     4mS Locked                    @Fast mode
Recommend Supply Voltage :    3V to 8.4V
Shutdown voltage :2.1(+-0.15)V
Damage voltage   :>15V
Power supply noise cancellation  :<=15 VPP
Reverse breakdown voltage : >-15V
Output ports withstand voltage : >12V
Normal Current : <110mA
Operating Temperature :–40 to +80 °C
Also available as a UHF Futaba module
  • I know this is an old thread but I wanted to ask if anyone has real experience using this UHF JR Module with the Turnigy 9X?  I have a Turnigy, flashed it with er9x and installed the backlight and the 6 position Flight Mode switch. Works great.  Have a good LRS is my next step in FPV world.
    Thanks for any feedback,
    Mike
  • @ user 01: Thanks for the chart, it's well done!
  • The specs are very different from the EzUHF, if you can read. 2W > 200mW, no USB analyzer, firmware update etc.
    What we have is the ChainLink as cheapest, then Dragon Link, then Scherrer LRS, then ezUHF
    TLS/DL/CL are similarly spec'd
    ezUHF and RMILEC are both different
    See https://spreadsheets.google.com/ccc?key=0AodCPSAvVLOGdGV1djBDUVp0R0... for more information
    @Ramon L "theres cheaper DIY methods" where?
    Well Crist Rigotti from RCG just got a range 30.4km out and (63.2km) round trip. Not saying it's legal, but it's possible.
    1 hour and 40 minute flight.
    With no fancy design UAV.
    He used the UHF 433Mhz D link with stock antenna as RC gear.
    Thread about this flight.
    a3908942-62-100_3461a.jpg?d=1301609641
  • but its not made for Turnigy 9x specifically, its  made for JR/Graupner and compatible models like flysky/turnigy 9x
    so it's not $265 module for a $53 TX, its a $265 module  for a 500$ Tx if you select a JR 9XII
  • $55 Tx with a $265 module... jajaj 20-60km range... go 10km both ways, maybe less distance, and you will not have battery or gas. thats 1/2 thinking engineering lol in the case you are flying a solar powered UAV ...thats other case... but for the price mmmm not... theres cheaper DIY methods
    @Soti
    Yes! 60 Km is a little... But it's what the manufacture say.. Maybe it was proven with the sun and wind in the right angle... ;-)
    @Earl!
    Yes 53 $ Tx but as you know it's doing a pretty good job.
    I think It's a strong setup and still with budget in mind.
  • $265 module for a $53 TX ??
    But I have to admit the er9x with open source software is great.
    Earl
  • i just want to comment on the range: Bullshit
