New long range module for Turnigy 9X 9Ch Transmitter or other JR Radios.
Long range JR UHF radio system 265 USD
The new UHF RC system is based on Ham band and neighbouring band from 400mhz-470mhz, with the frequency hopping technology and frequency sweeping technology, you never need to worry about losing control of your precious plane.
Have short range trouble? this LRS has a range beyond your imagination. with a bad antenna, you may still get 20km range in the air, and with a super good 1/2 wave length one, you can even get 60km in the air.
RF output:1000mw-2200mw
Power comsumption: 300-600mA
Range: 20-60km in the air
Failsafe: Yes
High and low power selection: 1000mw or 2000mw output
Highspeed control: yes
Transmitter parameters:
Hardware frequency Range 400MHz to 470MHz
Frequency stability :2.5ppm
Output low-pass Filter :NONE
Band 1
Start frequency:415Mhz
Step frequency:480Khz
Channel :70
Band 2
Start frequency:433Mhz
Step frequency:30Khz
Channel :70
Output Power : 30DB Peak / 33DB Peak
Rate : 40Hz/66Hz
RF interface impedance :50 Ohm
Supply Voltage : 8.4V to 16V
Reverse battery protection:NONE
Logic Voltage :3-12V
Current :
330mA/520mA (@50 Ohm load,12V Supply Voltage)
250mA/440mA (@No-load,12V Supply Voltage)
950mA/1.6A (@RF Short circuit,12V Supply Voltage)
Temperature:50 to 70 Degrees Celsius
Receiver parameter:
Frequency Range 400MHz to 470MHz
Sensitivity : -112 DBM @0.1EBR(40Hz Refresh rate)
-111 DBM @0.1EBR(50Hz Refresh rate)
-110 DBM @0.1EBR(66Hz Refresh rate)
-108 DBM @0.1EBR(90Hz Refresh rate)
-104 DBM @0.1EBR(125Hz Refresh rate)
-104 DBM @0.1EBR(166Hz Refresh rate)
-101 DBM @0.1EBR(250Hz Refresh rate)
F/S turn on condition : >0.99EBR
Antenna gain : 2.15DBM
Step frequency :10kHz
Bandpass filter:Chip integration
Out-of-band rejection :No specific data
It can work with video and audio transmitter which frequency less than 300Mhz or higher than 500Mhz .
Refresh rate :40Hz50Hz66Hz90Hz125Hz166Hz250Hz
Hopping rate :40Hz50Hz66Hz90Hz125Hz166Hz250Hz
Hopping cycle:13Hz16Hz22Hz30Hz41Hz 55Hz 83Hz
Recover time :77mS62mS45mS33mS24mS 18mS 12mS
Response Time : 4mS to 25mS
PWM Output accuracy :0.5uS step ERROR<20PPM
PWM Output range : 0.5mS-2.5mS
PWM output cycle :55Hz @Normal mode
192Hz @Fast mode
PPM Output accuracy :0.5uS step ERROR<20PPM
PPM Output range : 0.5mS-2.5mS Each channel
PPM output cycle :50Hz@Normal mode & 1mS to 2mS Output
42Hz to 50Hz @Normal mode & 0.5mS to 2.5mS Output
50Hz to 83Hz @Fast mode & 1mS to 2mS Output
42Hz to 125Hz @Fast mode & 0.5mS to 2.5mS Output
PPM sync pulse width:4mS to 16mS Automatic adjust @Normal mode
4mS Locked @Fast mode
Recommend Supply Voltage : 3V to 8.4V
Shutdown voltage :2.1(+-0.15)V
Damage voltage :>15V
Power supply noise cancellation :<=15 VPP
Reverse breakdown voltage : >-15V
Output ports withstand voltage : >12V
Normal Current : <110mA
Operating Temperature :–40 to +80 °C
Also available as a UHF Futaba module
I know this is an old thread but I wanted to ask if anyone has real experience using this UHF JR Module with the Turnigy 9X? I have a Turnigy, flashed it with er9x and installed the backlight and the 6 position Flight Mode switch. Works great. Have a good LRS is my next step in FPV world.
Thanks for any feedback,
Mike
The specs are very different from the EzUHF, if you can read. 2W > 200mW, no USB analyzer, firmware update etc.
What we have is the ChainLink as cheapest, then Dragon Link, then Scherrer LRS, then ezUHF
TLS/DL/CL are similarly spec'd
ezUHF and RMILEC are both different
See https://spreadsheets.google.com/ccc?key=0AodCPSAvVLOGdGV1djBDUVp0R0... for more information
Well Crist Rigotti from RCG just got a range 30.4km out and (63.2km) round trip. Not saying it's legal, but it's possible.
1 hour and 40 minute flight.
With no fancy design UAV.
He used the UHF 433Mhz D link with stock antenna as RC gear.
Thread about this flight.
so it's not $265 module for a $53 TX, its a $265 module for a 500$ Tx if you select a JR 9XII
@Soti
Yes! 60 Km is a little... But it's what the manufacture say.. Maybe it was proven with the sun and wind in the right angle... ;-)
@Earl!
Yes 53 $ Tx but as you know it's doing a pretty good job.
I think It's a strong setup and still with budget in mind.
$265 module for a $53 TX ??
But I have to admit the er9x with open source software is great.
Earl
i just want to comment on the range: Bullshit
