New Vtail 8 build started
3689421938?profile=originalNice new build, based on 1/2 ally tube, RCT 750 kv motors, 30 amp 4S ESC's, 10 by 4.5 props.
Overall width 680mm , length 840mm
About 5 hours work in it so far, the centre section and motor mounts are pre made for me out of 2.5mm fibreglass
The aluminium is all hand cut and drilled (lots of holes) !!3689421854?profile=original
Nuts/bolts 3mm and 4mm
ESC's were stripped so they could be "daisy chained" on the input side, and have the motor wires direct soldered on the output side.
They are mounted on the side pods, as this keeps the high current DC (and associated mag fields) far away from the Magnetometer , about 120mm seperation
3689421750?profile=original3689421953?profile=original
FC is an ardu, with mag, gps and sonar.
Now to get into the code, and do a custom mix, will take the Y6 code, as its close , and modify it, will do one version for the Vtail 8 (needs 5 channels) and a version for the Vtil Y6/Y4 (needs 4 channels)
Batteries will be 4S 12000 mah (good for about 10 kg total thrust) and carrying a maximum of 1kg DLSR
  • HI Max, depends on what layout you want to run, would then depend on which of the motor configs are the best ones to modify, but essentially whichever motors are doing the VTAIL, any roll control equations need to be deleted, and for every other motor remove any yaw equations
    if you are doing a Y6 with a vtail instead of coaxial at the rear, you can use the standard code
  • Theres a file called motors_Y6 and thats the one i change, as its close to what i need
    motor layout is up to you, you basically decide on a number/channel for each one, and then work out the roll/pitch/yaw values to achieve what you want
    for your 10 motor setup,i would modify a H6 config file, as i doubt you need to control all 10 motors individually,
  • Finished
    3692267497?profile=original
  • Thanks Denny, yep a distribution board could have a circulating magnetic field :)
    OK, i think the motor code is right, modified a Y6 one
    front two motors from CH_1
    left middle motors CH_2
    right middle motors CH_3
    Left Rear Motor CH_4 (does left yaw control)
    right rear motor CH_7 (does Right yaw control)
    /// -*- tab-width: 4; Mode: C++; c-basic-offset: 4; indent-tabs-mode: nil -*-
    #if FRAME_CONFIG == Y6_FRAME//matts Vtail 8 mix
    static void output_motors_armed(){ int out_min = g.rc_3.radio_min; int out_max = g.rc_3.radio_max;
    // Throttle is 0 to 1000 only g.rc_3.servo_out = constrain(g.rc_3.servo_out, 0, 1000);
    if(g.rc_3.servo_out > 0) out_min = g.rc_3.radio_min + MINIMUM_THROTTLE;
    g.rc_1.calc_pwm(); g.rc_2.calc_pwm(); g.rc_3.calc_pwm(); g.rc_4.calc_pwm();
    int roll_out =  g.rc_1.pwm_out; int pitch_out =  g.rc_2.pwm_out;
    //left motor_out[CH_2] =  g.rc_3.radio_out + roll_out; // dual motors
    //right motor_out[CH_3] =  g.rc_3.radio_out - roll_out; //dual motors
            //front        motor_out[CH_1]         =  g.rc_3.radio_out + pitch_out;              //dual motors
    //back motor_out[CH_7]         =  g.rc_3.radio_out - pitch_out;       // CCW Right Rear motor_out[CH_4] =  g.rc_3.radio_out - pitch_out; // CW Left Rear
    // Yaw motor_out[CH_4] += g.rc_4.pwm_out; // CCW Yaw right motor_out[CH_7] -= g.rc_4.pwm_out;  // CW Yaw left
    // limit output so motors don't stop motor_out[CH_1] = max(motor_out[CH_1],  out_min); motor_out[CH_2] = max(motor_out[CH_2],  out_min); motor_out[CH_3] = max(motor_out[CH_3],  out_min); motor_out[CH_4] = max(motor_out[CH_4],  out_min); motor_out[CH_7] = max(motor_out[CH_7],  out_min); motor_out[CH_1] = min(motor_out[CH_1], out_max); motor_out[CH_2] = min(motor_out[CH_2], out_max); motor_out[CH_3] = min(motor_out[CH_3], out_max); motor_out[CH_4] = min(motor_out[CH_4], out_max); motor_out[CH_7] = min(motor_out[CH_7],  out_max); #if CUT_MOTORS == ENABLED // Send commands to motors if(g.rc_3.servo_out > 0){ APM_RC.OutputCh(CH_1, motor_out[CH_1]); APM_RC.OutputCh(CH_2, motor_out[CH_2]); APM_RC.OutputCh(CH_3, motor_out[CH_3]); APM_RC.OutputCh(CH_4, motor_out[CH_4]); APM_RC.OutputCh(CH_7, motor_out[CH_7]); // InstantPWM APM_RC.Force_Out0_Out1(); APM_RC.Force_Out6_Out7(); APM_RC.Force_Out2_Out3(); }else{ APM_RC.OutputCh(CH_1, g.rc_3.radio_min); APM_RC.OutputCh(CH_2, g.rc_3.radio_min); APM_RC.OutputCh(CH_3, g.rc_3.radio_min); APM_RC.OutputCh(CH_4, g.rc_3.radio_min); APM_RC.OutputCh(CH_7, g.rc_3.radio_min); } #else APM_RC.OutputCh(CH_1, motor_out[CH_1]); APM_RC.OutputCh(CH_2, motor_out[CH_2]); APM_RC.OutputCh(CH_3, motor_out[CH_3]); APM_RC.OutputCh(CH_4, motor_out[CH_4]); APM_RC.OutputCh(CH_7, motor_out[CH_7]); // Instan
  • I have to say Mat I could not follow the logic of not having the daisy chain. Saves some weight. Is a power distribution board not  flowing in one direction also?
  • Makes me laugh, the only comments are to do with power wiring - you would think with my background in electronics I might get the basics correct.
    No comments on airframe design, coding the ardu........... sigh ......... :)
    @chuck - by feeding the first esc direct from the battery, and then sucessivly feeding each ESC from the last, each ESC in the system will progressivly get less available voltage.
    by daisy chaining, one to the other, with the negative lead from one direction and the positive from the other, we should get the same average voltage on all ESC's (daisy chain is probably the wrong term)
    @sebastian - please draw me a picture of how you expect the magnetic field to develop.
    i would have though as i have two seperate banks of ESC's about 240mm apart, fed from seperate batteries, seperate power leads, powerleads run together to cancel any fields, and certainly no power carrying conductors circling the APM - i should probably post a picture
  • That doesn't make any sense to me.  Power flows one direction through each ESC.
    it isn't going to flow through all four ESCs as a complete loop.  Just four small loops.
    I don't see where it makes any difference what side the beginning is.
    If you're paranoid, just flip two of them over.
    Looks like 12 gauge main feeds.  41 amps.  If they aren't melting at full throttle it will be fine.
  • Why would you like the black and red on the same side ? it defeats the purpose of the "daisy chain setup"
    those wires will carry on average 25 amps, and are rated at 50 amps, i am sure on the short run they will be fine :)
