Just wanted to let y'all know the Nurf Kit has been released.
Build videos, assembly instructions, and plans are also available here:
https://www.flyingfoam.com/content/nurf
It's even made in the USA.
@Ian, The airfoils are on the plans. They are something we cooked up in XFoil, but they are just a cross between an MH60 and S5010(?). Tip airfoil has the LE radius increased to help with tip stall.
@Gary, It's 5 mil lamination film and comes with the kit. Sometimes called New Stuff over at RC Groups. Otherwise the color is trim tape. Lamination film will hold paint but we never have time for it to dry around here.
@Jack, correct but we are in different markets so should not be cause for customer confusion.[Knock on wood.]
@John, Thanks! Just an attempt to squeeze a little more efficiency out of the wing. Theory says span-wise flow goes from tip to root and helps reduce tip vortices. Practice says it looks cool and flies great so we'll stick with it. It also helps put the wing root towards the back, which leaves all kinds of room for gear in the fuse. Otherwise forward sweep has a bit of stigma from issues like aeroelasticity and transonic flow that do not come into play at our scale or speed.
What's the deal with forward swept wings just looking ridiculously cool..
Just like the sexiest jet ever built, the NASA X-29.
Yes, using an existing brand name to sell more of your product is bad.
Nice covering job, what did you use?
Ahh, I forgot all about getting nurfed while surfing. Board to the nose if I remember correctly. Not a surfer though.
I thought you were a surfer dude and using slang for hitting someone. (Not the dirty version)
Ha. Officially it's short for Nurflugel. Unofficially it is a bit like a football my brothers and I used to hit each other with.
It's like having a sign up that says "beware of dog", and then someone gets bit, the lawyers can prove you knew it was a danger!
Just kidding!
Looks great.
