I didn't know about the problem when I bought my converter and IR trigger. Fortunately I haven't been affected. I like that your controller is adjustable, but if I'm pointing at my target I want to shoot flat out. What sort of situations do you imagine it will be useful for?
For mapping there is now a trigger per distance feature in APM (arduplane at least, I'm not sure if that exists for arducopter).
I would imagine the HDMI cable out location can be a bit of a bugger for some gimbals, and if it's a stiff cable it might upset the gimbal balance/movement. What is the gimbal you're using?
Thanks moglos. When looking at IR control for the Nex, the problem you posted about was what I read. Initially I decided to design my own controller as it gave me more customised control for trigger etc. I have not only the single shot, but I can also modify the timings for continuos trigger. I've added the facility by using one of the dials on my controller to alter the shot rate from 1 shot per second upto 1 shot every 30 seconds. All this by PMW control of course.
Would people be interested if I were to supply the IR controller?
I shall have another look at th HDMI output as I bought a HDMI to RCA converter in preparation. The other reason I went for a separate FPV camera is I can still use the mini camera, without having the Nex as part o the payload.
Hi Steven. I've got a NEX 5N and I don't have any trouble controlling the shutter and video while I've got HDMI out running. I'm using a converter that looks like this and this GentLED IR trigger.
Gentles has a page on the problem here, I haven't noticed the problem (I use auto focus) but I'll verify that I am getting shots every 2.5 seconds, there may be gaps that I haven't noticed.
I've also tried a second fpv type camera, but the HDMI out means I can better see exactly what the camera is capturing, and I can see when it is taking shots (it's easy to get stuck in movie mode and not realize you haven't stopped it).
Hi Steven, would you be able to please share the code you're using to trigger the nex5 with the arduino mini? I have picked up the necessary hardware and would like to get my one to do the same thing. You have yours set to accept a PWM input and trigger the camera based on that right?
Its a full carbon fiber frame and landing gear etc.
Props are 12 x 4.5 full carbon fiber on 880kv jDrones motors with 40amp ESC and 2 x 5000mAh batteries.
Flight time is unsure yet, as I haven't flown it. I wanted to take the pictures before anything went wrong :-)
Calibration is now complete, so it should go for its for flight in the next couple of days.
As for the FPV camera, I am not using it for FPV as such, that particular camera is there purely to help position the main Sony Nex5 for aerial photography. I may add a second smaller FPV camera for FPV flying in the future with a switch to select between the two.
Unfortuantely the Sony NEX 5 does not have composite out, if you use the HDMI out and then convert it, you loose IR control for shutter and video switch etc which is important to me.
I have built a small Arduino Mini which links to the Nex 5 by IR and allows me to switch video on and off, or switch over to photography mode and trigger the camera or leave it on a timed 5 second auto trigger.
More to follow I guess when shes had her maiden flight :-)
Cheers
Thank you for your comments.
one thing that I noticed.
You set FPV camera on a gimbal ?
That is not good since gimball will correct itself and you would not be able to 'feel' the octa.
Would you mind to share your motors/props/weight/flight time etc.
Nice pics!
Nice! Thanks for sharing.
