Octopilot -- Open source propeller-based autopilot
small.jpgOctopilot is open source autopilot hardware and software for radio controlled planes. It is based on the Parallax Propeller microcontroller, and uses a 5-degrees-of-freedom IMU plus a GPS and proximity sensor to stabilize and navigate your plane.It can be enabled/disabled through an extra channel/switch on your transmitter, and when switched on, stabilizes the plane and navigates it back to the starting location, where it will circle. It can also optionally trigger external actions, like taking a photo or dropping an item, when it reaches a waypoint.Coming soon: multiple waypoints, stabilization of inverted flight, on-board TV-out, and more.If you're interested in helping out, there's lots to be done! Swing on over to the project page and join the octopilot group.http://code.google.com/p/octopilot/
  • Good question. :) It's not soldered to the board. It just plugs into a 3x6 pin socket, which *is* soldered to the board. The receiver costs about $50, but I already had this receiver in the plane that I'm using for this project. It should work with any receiver that allows setting a failsafe throttle value, which is the throttle value that gets used if the receiver stops being able to hear the transmitter. And that's just to allow the board to know to switch back from manual to autopilot in this situation, which I guess is optional, but it seems important to me.
  • Looks nice,
    I see you use a spektrum reciever.is it solderd to the board?
    What will it cost?
    Remco
