Open Source Laser Range Sensor Converts the Speed of Light into the Speed of Sound
Press Release, February 2014:
In a direct attack on both the laser rangefinder market and the ultrasonic rangefinder market, LightWare Optoelectronics (Pty) Ltd, a South African based manufacturer of laser rangefinders, has begun production of an open source laser sensor (OSLRF-01) that can convert signals traveling at the speed of light into signals traveling at the speed of sound. This sensor has all the benefits of a laser rangefinder, like direct aiming, long range, immunity to noise and wind and high accuracy but non of the headaches associated with the super high speed circuitry normally found inside laser products. Instead, the OSLRF-01 outputs analog signals that look just like those found on an ultrasonic sensor. These speed-of-sound signals can easily interface directly with the ADCs of a microcontroller where conventional ultrasonic signal processing and timing algorithms can be applied to the data.
If the speed of sound is too slow for you, there is a control input on the OSLRF-01 that lets you select what Mach number you want to work with, anywhere from Mach 0.1 up to Mach 5. Running at higher Mach numbers means that the analog signals get faster and the time it takes for the laser/ultrasonic pulse to make a round trip gets shorter. So if your processor can handle the additional speed, you can have a quicker response time.
The OSLRF-01 can be used as the "bare metal" front end in a complete laser or ultrasonic rangefinder, or it can become a conventional distance sensor connected directly to the host processor on small robots, UAVs or UGVs. All the components on the OSLRF-01 circuit board are readily available from the large electronics components suppliers and there is no electronic trickery hidden inside ASICs or FPGAs. The OSLRF-01 doesn't even have a processor, so there's no fancy software to worry about either.
A brief technical description and circuit diagram can be found here: OSLRF-01 description. With input from the open source community, the OSLRF-01 could one day become the foundation of many other sensing devices such as scanning LIDARs, proximity sensors, depth/width/height gauges, obstacle detectors and altimeters.
LightWare is currently selling the OSLRF-01 at US$100.00 excluding shipping and local taxes. For sales enquiries visit: LightWare Optoelectronics (Pty) Ltd
I've had a few enquiries from people who want to use the OSLRF-01 in bright sunlight. Whilst the unit will still operate, sunlight injects unwanted photons into the detector and this creates electrical noise which can make it harder to find small return signals. The best way to cut out this noise is the use a narrow band, optical filter that has a pass-band which matches the color of the laser. These filters appear opaque to sunlight and block out all but a very small portion of the solar spectrum (see picture below).
The OSLRF-01 has been designed to accept one of our standard optical filters (905nm) and if you want a unit with a filter then order the OSLRF-01 and filter separately and we will instal the filter for you at no charge.
Hey Doug, there are quite a few differences between the SF02/F and the OSLRF-01. The most obvious being that the SF02/F has a 32 bit, Arm processor and FPGA to control the LRF functions. Other component differences include the optical filter, APD detector and the timing system.
In the SF02/F, the optical filter has a very narrow passband band that's matched to the laser and it gives the SF02/F better performance in bright sunlight. The APD detects the return signal and it's about 100 times more sensitive than a regular photodiode, hence the longer range. Both the optical filter and the APD are very expensive components but are critical to the performance of the SF02/F.
The timer on the SF02/F is an interesting system. It's based on something I saw at McDonald Observatory in Texas quite a few years back. The guys running the LLR program (Lunar Laser Ranging) were discussing how to improve the accuracy of the timing system they were using to measure to the Apollo reflectors on the moon, and I was stunned to see that their existing system used an analog ramp interlaced between digital clock cycles. I've always wanted to have a go at designing something similar, and when they shut down the LLR a few years ago, I started working on the timing system that you now have in the SF02/F - a small tribute to the awesome work that the people running the very last Apollo project had done.
@Ranaud - No. If you want plug and play, look at the SF02. The SF02 is more money, but also 4x the range.
@Laser Developer - I have also been testing the SF02 and have been really happy with it thus far. A cursory read of the OSLRF-01 data sheet makes it appear that it has the same laser. Is the reduced range purely a function of the higher update rate and is there any ability to change that?
I have to say, I'm talking about the products these OEM type sensors might be found in. My mistake for not making it clearer.
Well, at least we can access the Lightware webpage - more than can be said for the 'sick' SICK.com page....
Hi Laser Developer,
I don't know if you're the same person I've had a couple of conversations with over email, but I just wanted to say how pleased I am that you guys are bringing this to us. Looking at similar products, the prices are crazy, so I'm really happy to have the ability to take your kit and include it in my designs for future products!
Cheers,
Phill
Thanks again!
Dan, the main advantage of this technology is that you can push the range a lot further than most of the TOF camera devices and right now it is cheaper. However, we acknowledge that specialized TOF chips will be the wave of the future and, since we like riding this kind of wave, we will be releasing 1D, 2D and 3D TOF cameras based on these chip sets in the future as part of our regular product lines.
Thanks for the kind words Joe. Please contact me directly for changes to the SF02 - I'm keen to explore different configurations.
Hi there Laser Developer..Joe from Swakopmund..
The SF02's I got from you are doing a sterling job in our mk-IIc Aircraft! If interested have a look at my blog on the SurVoyeur mk-11c...
http://diydrones.com/xn/detail/705844:BlogPost:1533088?xg_source=ac...
I really like the SF02 and it has cured all my aches and pains with the pressure alt sensor for autoland.
We are working on a nice contract for some SA entities, and will I need a small handful of the SF02 in the next weeks, so will contact Tracy this week.
One query, the form factor of the SF02 is a little awkward for us, long and thin, we would really like a squat and fat module, basically to fit forward of the CG, under the battery bay. Should I contact you to understand the implications?
By the way, the downsampling process you use in the OSLRF is what we used in the UWB radar rangefinder we developed, but the SF02 made a COTS solution much easier! I would still like to pursue the RADAR solution, but along the lines of our current development using the old FMCW/Doppler technique for a seek and avoid radar.
Nice Going!
Regards
Joe
Lser Developer, for me it does not matter if it was hands on big companies, what truly matter is if it is hand's on developers:). Because they are the one who are shaping the technology.
1
2
of 2 Next
