3689629082?profile=original
I have worked hard in my sparse time to improve OpenFPV. I got a lot of mails from interested people around the world and can't wait to share the latest results with you. Your support is amazing, and my goal is to bring this project alive as soon as I can. Special thanks for all who donated a few bucks to the Project, every dollar helps me a lot.
A quick overview from the last month:
  • MinIMU-9 v2 Gyro, Accelerometer, and Compass test integration
  • Further latency optimisation
  • 160° Wide Angle Fish Eye Camera
  • 5 GHz transmission tests
  • Oculus Rift DK2 Support (experimental)
  • 720p at 40 FPS Tests
  • Source code re-structure
  • Optimised video rendering
Pro:
  • The gyro integration works pretty good so far
  • Telemetry overlay works well with the gyro
  • The gyro data transmission works even if the video feed is broken (separated data channels)
  • The latency is is now stable over hours and pretty promising
  • The wide-angle camera does the job pretty good, nothing else to say
  • The new 5 GHz (diversity) adapter gave me really good results and is affordable (20 € each)
  • The Oculus Rift was mind blowing - The image is that big that I'm not able to describe
  • The source code is now better structured and modularised
  • 720p (1280x720) works good on the ground, not tested in the air
Con:
  • The CPU Load is to high on the ground station (20% / 400%, 640x480 H264, 2.3 GHz I7, MacOS)
  • No hardware decoding for the video stream
  • No Telemetry data for the oculus at the moment
  • No Fragment shader for Oculus Rift distortion
  • Bad weather in Germany
The Roadmap for 2015:
3689629175?profile=original
  1. Between January and February I will release a first access to the project. This version should be stable enough for testing.
  2. Between May and June I will release a updated version with improvements from the community
  3. I target August 2015 as a first "release*".
* what means release:
  • Easy to install
  • Documentation
  • Download a Ready To Fly image for the raspberry
  • Maybe sell a complete setup online (amazon)
(Please note that all dates are in subject to change, depending on issues, bugs, time)
Some pictures from the lab:
3689629217?profile=original
Me holding a prototype with 5Ghz diversity, 160° fish eye camera. I can even write messages on my phone trough the oculus live feed with this setup. Can't show you how it looks like, but all who tested it in my lab are amazed.
3689629189?profile=original
Screenshot from the oculus mode. *Note the missing fragment shader for the rift distortion, this is not 3D (but possible in the future, you will see a huge 2D screen in front of you)
3689629239?profile=original
The prototype with attached 5Ghz adapter watching birds.
I have no in flight footage yet, the main reason is the bad weather here. But I will do some recordings, pictures if the weather is a bit better and I have enough time and a working drone / plane*, you have my word.
* My last plane crashed and destroyed one OpenFPV Setup while testing
TL;DR;
- First release for developers between January and February 2015
- First "consumer" release summer 2015 (maybe later)
If you have any questions, please leave a comment below or write me: contact@openfpv.org
Tilman
  • @Bim The chipset is: RT5572
  • @Bim, thanks :) - I got them from amazon, a german company called CSL is distributing it. I know there is a raspberry compatible ralink chip inside. I not tested the ranke yet, but it is promising.  I know that it supports up to 30db if it is allowed in your country, and 5.8 GHz. It is better to use a good antenna but to have the option to use more powers is always good.  The downside of the CSL usb adapter is the quality of the "gilded" usb interface, this fit's not 100% inside the port and wobbles a bit, but this could be fixed. Here is a link to the adapter (german): http://www.amazon.de/gp/product/B00LLIOT34 - regards
  • @lot Thank you, that should be possible, I have not a lot of experience with android but I will work on a LTE version with iPad / iPhone, android support in the future.
  • Everything sounds amazing, congratulations!
    Do you think that is possible to made this with a smartphone in a google cardboard ?
  • Fantastic work Tilman,
    I have a DK2 and look forward to implementing your system when you release it.
    I'll start with it on my rover or robot then move to a quad as well.
    I know how great Oculus is and how important minimization of latency.
    Best Regards,
    Gary
