A new platform "OWL" will soon be ready for small RC UAV / FPV flying.
The plane will look like this:
The model are made in glassfiber and balsa:More info on the OWL will come in the near future!A new Platform based on the Multiplex Alfa 2100 are on the Drawing board.Modified as a pusher.Wingspan 2.1MVery stabel platformGood for payload.
Button
I promis more will come when one sample is ready.
But I can say - it's hard work.
The wings will either be made in balsa or glassfiber - I would like to make a model which can take a little beating in landings, I think the balsa are a little too fragile but the weight also need to be in the low end.
Palmer
You only buy the platform, the rest is up to each. I know people has diffrent opinion about servos, motors and camera ect. So yes you will need some working yourself before it's in the sky.
Bosak
were you thinking about something like this.
"I know the OWL are not for rc beginners, you need to know a little about CG to have succes. But I think that most people in here are advanced RC users."
When you add 100g at the front (on the field, in a hurry), you must either add 100g in the back or move the wing. 100g is the difference between digital cam and flycamone v2 for example. Good you predicted the necessity of rail with counterweight.
BTW before going pro think about Picatinny.
KrzysZtof
As you know!
Everything is possible, but the OWL v.1 is a low budget plane made for FPV / UAV.
For the front I can say that I'm working on using a glass ball from a doomcamera. It need to be modyfied for fitting the front.
About the CG I was thinking about mounting a small track under the belly with a small moverable weight appeared. This way it's possible to adjust balance on the plane so the right CG would be able to find without moving the battery and so on... The weight appeared are only for fine adjustment (10-20 g).
Hope you understand my point.
Apart form my previous remarks about fragile cam in the nose, the project has no provision for moving the wing forward and back.
With main payload in the nose, this is asking for troubles installing various cameras.
Of course I like the project, it's beautiful. But It can be problematic since it follows the big company thinking where we agree on one fixed payload then design an airframe. Pity the mold is done.
Weight at this moment are under 500 g
Great job. Will this be a Ready to Fly (RTF) or the plane as a kit and we need to fit with engine and controls?
Your mouldings look great, tell us a little more about how the plane is made, were the plugs hand carved? Are the wings vacuum bagged? etc,etc.
Cheers,
Bosak
20 cm and made of strong plastic... 4 = 25 $When you add 100g at the front (on the field, in a hurry), you must either add 100g in the back or move the wing. 100g is the difference between digital cam and flycamone v2 for example. Good you predicted the necessity of rail with counterweight.
As you know!
1
2
3
4
5
of 5 Next
