Part Two: Here is the original picture of the finished product:
3689618661?profile=original
This is the second part of a 2-part series on 'How to build a High-Definition FPV UAV using a Raspberry PI with HD camera, using a high speed WiFi link.
In my first post on the subject (located here), I discussed the parts I used, and how to install them into a Hobby King Go-Discover FPV model.
In this post, I will discuss installing the Raspberry PI and the PI camera in the Go-Discover gimbals, and the software configuration for both the Raspberry PI and the ground station PC.
From the previous post, step 3 was completed by installing the Ubiquity Rocket M5 in the model.  Now onto step 4:
Step 4: Install the Raspberry PI and PI Camera
Here is a photo of the position of the PI in the Go-Discover model:
3689618887?profile=original
The PI fits nicely just behind the camera gimbals, with the USB and HDMI ports on top. In the right side you can see the Cat5 network cable attached. This cable connects to the ethernet switch, which is also connected to the Rocket M5 input port.
The two cables shown on top are the servo control wires for the gimbals, which I have directly connected to channel 4 and 5 on my radio.  I am using channel 4 (normally the rudder stick on my radio. Since there is no rudder on a flying wing, this is a convenient channel to use to move left and right with the camera. I have not (yet) moved to a head tracker, but if you already have that setup, just assign the channels accordingly.
To install the PI camera, remove the stock plate from the gimbals (for a GoPro), and mount the PI camera as shown in this photo:
3689618926?profile=original
The PI camera case fits very nicely into the slot, and again I used a small piece of velcro to hold it down. You could use a couple of small screws instead if you want a more secure hold.  The two gimbals servos are also shown here. They are simple to install, just follow the Go-Discover instructions.
Here is a front view of the PI camera installed:
3689618962?profile=original
Here is the block diagram describing all the connections:
3689618829?profile=original
Some comments on my previous post suggested that it is possible to eliminate the ethernet switch and serial-to-ethernet converter using the Raspberry PI and a serial port on the PI. I believe this post describes how to talk to the PI via the NavLink, but in this case, I want to use the PI to bridge the connection from the ground station to the APM/PixHawk. Somebody please comment on this if you know more about it.   I believe it would require a TCP/IP to serial link from the PI to the telemetry port on the APM, and some software on the PI to act as the bridge.  The main connection to the ground station is via the Rocket M5 and TCP/IP, not through a telemetry link (900 Mhz or Zigbee like I used on my other models).
Step 5: Getting it all to work with software configuration (the really fun part starts now).
Check out this post on what others have done with streaming and the PI.  My experiments showed that using GStreamer on both the PI and on Windows gives really good results with very low latency, if you use the right parameters.
Get GStreamer on the PI by following this blog.   This is the same version of GStreamer that I am using on my setup.
Make sure your PI camera works ok by plugging in the PI to a standard monitor using the HDMI port and follow the instructions on the Raspberry PI website on how to get the camera up and running (without GStreamer).  Once you have a working PI and camera, you can then proceed to stream things over the network.
Note: It is suggested that you first get the PI streaming video by plugging it directly into your local network where you can also connect your ground station PC with the correct IP addresses (without the Rocket M5).   For my PI, I picked 192.168.1.2,  and for the ground station, 192.168.1.1.    Make sure you can ping the PI from your PC and the PC from the PI.
For streaming, you will also have to make sure all the ports you intent to use are open on the firewall (described later).
For the ground station PC,  you can download GStreamer here.  Make sure when you install, select to install everything , or full installation (not the default).
Here is the command I use for the PI to pipe the camera output to GStreamer:
raspivid -t 0 -w 1280 -h 720 -fps 30 -b 1700000 -o - | gst-launch1.0 -v fdsrc ! h264parse config-interval=1 ! rtph264pay ! udpsink host = 192.168.1.1 port= 9000
The command is explained as follows:
raspivid is the command to start the camera capture on the PI.  The -w switch is for the width in pixels, and the -h switch is for the height.  In this case, I am using 1280 X 720, but you can try any combination that fits your needs.
The -b switch is the bit rate for the sampling. In this case I chose 1.7mbs to send over the stream. Again you can experiment with higher or lower values. This settings seems to work good for me, and the latency is almost unnoticeable.
the "-o - |" is piping the output to gstreamer.  Make sure you include the dash before the pipe "|" symbol.
For the GStreamer command, all the filters are separated with an exclamation point "!", as these are individual drivers that are part of GStreamer.  Since the PI has hardware accelerated video, the output is in a format called "H264", which is a highly-compressed stream. The GStreamer filters are configured to transport the output via a UDP socket connection to the target PC. Notice the 'udpsink' element which specifies the host - in this case your ground station, and the UDP port.  I am using port 9000, but you can use any open port on your system, but be sure to open the firewall or it won't work!  You can also use TCP instead of UDP, but for such a data stream, I chose to use UDP since dropouts are certainly possible, and with UDP this is ok, but with TCP, you could have socket problems and higher latency.
Note: to get the PI to execute this command on boot, make a shell script with the above command and add it to your local.rc boot sequence. That way when the PI boots, you get the stream without having to log into the PI remotely.
For the ground station PC, once you have installed GStreamer and opened the correct ports, use this command (from the command prompt) to view the stream:
c:\gstreamer\1.0\x86_64\bin\gst-launch-1.0 udpsrc port=9000 ! application/x-rtp,encoding-name=H264,payload=96 ! rtph264depay ! avdec_h264 ! videoconvert ! autovideosink
If all goes well, you should see the PI camera output on your PC screen in a popup window.  For those of you what want to use FPV goggles, you can connect to the HDMI port on your PC to display the output if your goggles support HDMI.
I have this command in a batch file (with a PAUSE) statement at the end to keep the window open.
WHEW!  If you got this far, you are amazing.
The last step to complete the build is to connect to the APM from mission planner.  The method I used to connect was to install a utility that converts a TCP connection to a virtual serial port, but I also think that directly connecting the mission planner to the TCP port will also work, however I have not tried it. I will post back later after trying it.
Here is the link to setup the serial to ethernet device to have an IP address and port.
Here is the link to the configuration utility for installing the virtual serial port.
Once you have a serial connection over TCP/IP working to the APM, you should be able to connect with Mission Planner. On the maiden flight, it worked perfectly, and I didn't see a single drop in the telemetry data or anything noticeable in the video transmission, however my first flight was limited to 2km.
The last step is to connect the Rocket M5 to the Nano M5 and test everything using the OTA (over the air) connection. If all is well, you are ready to fly!  But be careful on your maiden, you just spent $700.
Finally, here is a photo of my Antenna Tracker with the Nano M5 attached. My next update will include a video of a longer flight.
3689618942?profile=original
Happy Flying!
  • I got it working, but the solution is quite strange. I tried to change the config-interval=5 as mentioned above and reboot the Pi. Now it works perfectly, even if I change back to config-interval=1. I have no idea why it's like this, but now I can stream it.
    The Android HUD you provide works nicely as well. Thank you Patrick for all your work.
  • I'm trying to stream the video from pi but it stucks with: "New clock: GstSystemClock"
    I'm using this command: raspivid -t 0 -w 1280 -h 720 -fps 40 -vf -b 2000000 -vf -hf -o - | gst-launch-1.0 -v fdsrc ! h264parse ! rtph264pay config-interval=1 ! udpsink host = 10.0.0.13 port= 9000
    Having tried to google solutions but I still could not figure out what the problem is. Does anyone know what the cause is?
  • @Patrick I understand the undertaking of compiling the project targeted to android. It will be very valuable to have it properly documented.
    I want an opengl map layer beneath video, with ahrs synchronized to simulate a flight simulation view. If implemented correctly, the operators could check real fpv against GIS terrain rendering on the fly. Of course some issues like altitude, FOV, terrain slopes exaggerations need to be carefully processed to make the flight journey enjoyable, however I think it will be greatly helpful to aid a bench pilot get orientation.
  • @Jerry,  I am swamped with stuff that actually makes me money, but this weekend I will be posting the instructions and updated release with the .pro files that you need for qtcreator.  Buildirg for Windows is relatively simple, but building the Android version is a bit tricky compared to Windows because of the dependencies in Android. You need the NDK, and an Android version of the Boost C++ libraries, and the Android GStreamer binaries pre-compiled for ARMv7, and a few other custom mods that are different than windows.  The core source is the same as windows, but the dependencies are not. You also have to build a custom version of QtGStreamer that I modified for Android because the windows version does not work on Android. This is part of what I will be posting to GitHub shortly.
    Mapbox looks interesting. To answer your question, it's possible to alpha-blend on top of any image, similar to what the live video HUD is doing.  What kind of view are you looking for in the map display? Something similar to Mission Planner to show the position of the UAV in a separate tab?
  • @ Patrick
    I'd love a QtCreator version for android apk. right now i have two Nexus7 on hand, one run QtGstreamerHUD, and the other run Mapbox GL android. I'll look into how to integrate mavlink into Mapbox opengl running on android natively. (If you are interested, please have a look into Mapbox GIS, i wonder if alpha bending is possible to integrate a transparent google earth like layer on QtGstreamerrHUD).
    I figured out my latency issue: i put a multicast address to the pipeline, to void configure gst client ip address, it looks like the kernel is posting the socket into every masked address rather leave the work to L3 hardware( i supposed) .  the symptom was so funny that looks like UDP also has a buffer in the vid...maybe my knowledge in tcp/ip is wrong, i'll re-read some books to justify my understanding.
    very happy now with LAN testing results. I'll try ubnt configs then have a field test. I'll post some 3D printing case models when i have a satisfying print case.
    Thanks very much for your help and inspiration Patrick.
  • @Edward.   If you put the gstreamer commands in /etc/rc.local, the stream will never stop until you kill the process from a terminal.  This is normally how I run on my system.  Just curious as to why you want to stop the stream. On my UAV, the PI only does one thing which is send the video and telemetry so I never stop it.  Seems like I tried starting the video stream from a remote terminal and it worked on the latest build of Raspbian, so if you don't like the auto-run in rc.local then I would say give that a try.
  • Hi there - thanks for the awesome guidance through all this. I am wondering why when I initiate the stream on the sending Pi and it won't stop sending. The only way to really stop it seems to control z out and that really doesn't even do much, the red camera light stays on and the only real way to really get it to stop is to ssh in and logout twice to stop all processes. Tried on two different builds and two different Pi s. Second this is that I have to initial the receiving end prior to the sending side. I've been following this thread since the beginning and that seems consistent with what I've read but is there a work around - something in config-interval=1? I am using:
    raspivid -t 0 -b 5500000 -n -o - | gst-launch-1.0 -v fdsrc ! h264parse ! rtph264pay config-interval=1 pt=96 ! gdppay ! udpsink port=9001 host=192.168.1.8
    Thanks in advance.
  • @Jerry, to compile the HUD code, I used Visual Studio 2010 not QtCreator, but I have since switched since I created the Android version.  I will be posting a new version soon that has the instructions.
  • @Jerry, glad to here that you figured out the frame freezing problem. I should have mentioned the 'config-interval' issue, as I saw that same thing a while back, but never posted it.
    As for your issue with UDP, I have never experienced what you are describing. It does sound like you are dropping packets, but at a close test range, this should not happen. The main issue with TCP is the accumulated latency you will get if the UAV looses the connection, and the stream has to 'catch up', because the packets get queued until the connection re-establishes.    If you drop the connection with UDP, it's not an issue because the stream can re-establish itself with a frame or two.
    Send me your gstreamer commands for both the PI and your ground station and I'll see if I can reproduce the problem.
  • @Patrick I have been testing rtsp over UDP pipeline you demonstrated in the blog, however the bench test result is worst than a tcp connection. I understand basic video compression concepts, like motion prediction and DCM, i could see lots of artefacts was introduced in UDP transmission pipeline, especially when moving objects in the video gets more significant area. when using TCP, the lag accumulates due to the TCP buffer accumulating in kernel (my guess), but much better result, this could be decoder was not dropping data during transmission.
    I could not generate a scientific testing results, due to poor skill sets and overwhelmingly various crossing fields of technologies. my goal is build a reliable comm line specific for drones, with IEEE 1158 timing sync, TDMA sync and vehicle travel speed compensation, OO middle ware for comm like mavlink, and real-time video for remote control, all done in a single Zynq SoC. this is a too loooong shot.
    back to the problem, do you have some suggestion with gstreamer pipeline to sync frames in TCP, dropping frames if decoder or tx/rx latency metering method. or this has never been done, need to start by writing new plugins?
    getting frustrated in the testing, i think i need to start "from the formula", testing ubnt network by profiling MAC packets and optimise the latency by RTS/CTS profiles. and profiling H264 hardware encoder in Broadcom ASIC, and Linux Kernels, socket, TCP/IP layer implementations, 802.11 drivers etc.
    at last i have a simple and stupid question: how to compile your code at https://github.com/pnduffy/GStreamerHUD/tree/master/QtGstreamerHUD ? I am a qt noob and could not see and .pro file to import the project.
    Many thanks for your previous support.
    A fork of Mission Planner that has a GStreamer/Qt-based High Definition HUD. - pnduffy/GStreamerHUD
