Part Two: Here is the original picture of the finished product:
This is the second part of a 2-part series on 'How to build a High-Definition FPV UAV using a Raspberry PI with HD camera, using a high speed WiFi link.
In my first post on the subject (located here), I discussed the parts I used, and how to install them into a Hobby King Go-Discover FPV model.
In this post, I will discuss installing the Raspberry PI and the PI camera in the Go-Discover gimbals, and the software configuration for both the Raspberry PI and the ground station PC.
From the previous post, step 3 was completed by installing the Ubiquity Rocket M5 in the model. Now onto step 4:
Step 4: Install the Raspberry PI and PI Camera
Here is a photo of the position of the PI in the Go-Discover model:
The PI fits nicely just behind the camera gimbals, with the USB and HDMI ports on top. In the right side you can see the Cat5 network cable attached. This cable connects to the ethernet switch, which is also connected to the Rocket M5 input port.
The two cables shown on top are the servo control wires for the gimbals, which I have directly connected to channel 4 and 5 on my radio. I am using channel 4 (normally the rudder stick on my radio. Since there is no rudder on a flying wing, this is a convenient channel to use to move left and right with the camera. I have not (yet) moved to a head tracker, but if you already have that setup, just assign the channels accordingly.
To install the PI camera, remove the stock plate from the gimbals (for a GoPro), and mount the PI camera as shown in this photo:
The PI camera case fits very nicely into the slot, and again I used a small piece of velcro to hold it down. You could use a couple of small screws instead if you want a more secure hold. The two gimbals servos are also shown here. They are simple to install, just follow the Go-Discover instructions.
Here is a front view of the PI camera installed:
Here is the block diagram describing all the connections:
Some comments on my previous post suggested that it is possible to eliminate the ethernet switch and serial-to-ethernet converter using the Raspberry PI and a serial port on the PI. I believe this post describes how to talk to the PI via the NavLink, but in this case, I want to use the PI to bridge the connection from the ground station to the APM/PixHawk. Somebody please comment on this if you know more about it. I believe it would require a TCP/IP to serial link from the PI to the telemetry port on the APM, and some software on the PI to act as the bridge. The main connection to the ground station is via the Rocket M5 and TCP/IP, not through a telemetry link (900 Mhz or Zigbee like I used on my other models).
Step 5: Getting it all to work with software configuration (the really fun part starts now).
Check out this post on what others have done with streaming and the PI. My experiments showed that using GStreamer on both the PI and on Windows gives really good results with very low latency, if you use the right parameters.
Get GStreamer on the PI by following this blog. This is the same version of GStreamer that I am using on my setup.
Make sure your PI camera works ok by plugging in the PI to a standard monitor using the HDMI port and follow the instructions on the Raspberry PI website on how to get the camera up and running (without GStreamer). Once you have a working PI and camera, you can then proceed to stream things over the network.
Note: It is suggested that you first get the PI streaming video by plugging it directly into your local network where you can also connect your ground station PC with the correct IP addresses (without the Rocket M5). For my PI, I picked 192.168.1.2, and for the ground station, 192.168.1.1. Make sure you can ping the PI from your PC and the PC from the PI.
For streaming, you will also have to make sure all the ports you intent to use are open on the firewall (described later).
For the ground station PC, you can download GStreamer here. Make sure when you install, select to install everything , or full installation (not the default).
Here is the command I use for the PI to pipe the camera output to GStreamer:
raspivid -t 0 -w 1280 -h 720 -fps 30 -b 1700000 -o - | gst-launch1.0 -v fdsrc ! h264parse config-interval=1 ! rtph264pay ! udpsink host = 192.168.1.1 port= 9000
The command is explained as follows:
raspivid is the command to start the camera capture on the PI. The -w switch is for the width in pixels, and the -h switch is for the height. In this case, I am using 1280 X 720, but you can try any combination that fits your needs.
The -b switch is the bit rate for the sampling. In this case I chose 1.7mbs to send over the stream. Again you can experiment with higher or lower values. This settings seems to work good for me, and the latency is almost unnoticeable.
the "-o - |" is piping the output to gstreamer. Make sure you include the dash before the pipe "|" symbol.
For the GStreamer command, all the filters are separated with an exclamation point "!", as these are individual drivers that are part of GStreamer. Since the PI has hardware accelerated video, the output is in a format called "H264", which is a highly-compressed stream. The GStreamer filters are configured to transport the output via a UDP socket connection to the target PC. Notice the 'udpsink' element which specifies the host - in this case your ground station, and the UDP port. I am using port 9000, but you can use any open port on your system, but be sure to open the firewall or it won't work! You can also use TCP instead of UDP, but for such a data stream, I chose to use UDP since dropouts are certainly possible, and with UDP this is ok, but with TCP, you could have socket problems and higher latency.
Note: to get the PI to execute this command on boot, make a shell script with the above command and add it to your local.rc boot sequence. That way when the PI boots, you get the stream without having to log into the PI remotely.
For the ground station PC, once you have installed GStreamer and opened the correct ports, use this command (from the command prompt) to view the stream:
c:\gstreamer\1.0\x86_64\bin\gst-launch-1.0 udpsrc port=9000 ! application/x-rtp,encoding-name=H264,payload=96 ! rtph264depay ! avdec_h264 ! videoconvert ! autovideosink
If all goes well, you should see the PI camera output on your PC screen in a popup window. For those of you what want to use FPV goggles, you can connect to the HDMI port on your PC to display the output if your goggles support HDMI.
I have this command in a batch file (with a PAUSE) statement at the end to keep the window open.
WHEW! If you got this far, you are amazing.
The last step to complete the build is to connect to the APM from mission planner. The method I used to connect was to install a utility that converts a TCP connection to a virtual serial port, but I also think that directly connecting the mission planner to the TCP port will also work, however I have not tried it. I will post back later after trying it.
Here is the link to setup the serial to ethernet device to have an IP address and port.
Here is the link to the configuration utility for installing the virtual serial port.
Once you have a serial connection over TCP/IP working to the APM, you should be able to connect with Mission Planner. On the maiden flight, it worked perfectly, and I didn't see a single drop in the telemetry data or anything noticeable in the video transmission, however my first flight was limited to 2km.
The last step is to connect the Rocket M5 to the Nano M5 and test everything using the OTA (over the air) connection. If all is well, you are ready to fly! But be careful on your maiden, you just spent $700.
Finally, here is a photo of my Antenna Tracker with the Nano M5 attached. My next update will include a video of a longer flight.
Happy Flying!
Nice Work, Patrick but, I have an idea to greatly reduce the overhead of transcoding and allowing camera settings control in flight without interrupting the stream. I sent you a PM with a few hints
I retry with MP4Box to transform a h264 to mp4 but continue to have problem ... i saw that EOS is correctly introduce in the frame now the strange is the output of raspvid sucesfully transformed in mp4 the output of gstreamer have error :(
@Roberto, your recording problem is related to the EOS signal in the H264 stream. For the mp4 file to be valid in needs a header that has the EOS information, and when you use gstreamer, the only way to get the EOS signal is to stop the stream with a 'stop pipeline' command.
The way I handle this with the HUD app is to manually press the 'stop' button on the UI before killing the app. This inserts the EOS signal and the mp4 header gets written to the file and it works just fine.
@Roberto, TCP won't necessarily increase latency unless there is dropped packets. More data is transmitted with TCP, so if your connection is bandwidth limited, you will get more latency with TCP. The main problem with TCP is that it's a guaranteed delivery protocol, so if a packet fails to reach it's destination, it gets re-transmitted. This is certainly an issue with a system that is wireless and moving in the air. If you drop the connection, the packets get queued, and when the connection is re-established, you get a big latency until the stream catches up. For UDP, a drop just loses the data, but when you re-connect, the stream is back live (minus any normal latency).
I use UDP for both telemetry and the video. If you are controlling the UAV via the mavlink and not your radio, you definitely do not want to use TCP, as this could cause a BIG latency if you ever lose the connection.
I finish my last test about resolution if i reduce resolution to 1024 x 720 it's perfect on VR Pad Station ... i don't already test on your QT revision now i have finish the battery :( This evening try with QT .. a question i don't had doing good test with tcp connection my impression is that there is more latency what's your opinion about it ?
best
Roberto
I saw that for example i have same iusse when use RPI for decoding at high resolution i have some iusse i don't have any problem on my i7 laptop ... are you investigate if there is the opportunity to use gstream with special driver for hardware decoding acceleration ?
Other question i try to record on board the stream ... i produce the file .h264 but i cannot convert it to mp4 i have an error
Yes i know it's strange because I thought that LG3 is last technology available on the market but i agree with you try my application and tell me what do you think about. As i told you i don't have problem on Nexus 4 but with LG3 i have it.
best
Roberto
@Roberto, most likely your phone can't keep up with the stream. In my Nexus 6 it works fine with no latency, but my android tablet, it chokes badly because the processor is just too slow. The Nexus 6 has a Qualcom 4 core 'SnapDragon' processor that is fast enough to keep up with the stream. I don't think you can 'solve' that problem without reducing the resolution of the stream. If I switch to 800x600, then the Android tablet can keep up, but not at 720p or 1080p. It's just that simple.
In our app have similar problem on gstreamer only on some cellular phone on Nexus 4 no problem on LG 3 we have some iusse ... we are working to solve it before to release it.
Hi Patrick ,
i already implement the gstreamer in our VR Pad Station Pro with a lot of other advanced functionality ...
This is the like to an alpha revision .... https://drive.google.com/file/d/0B4DdeCEPBOEcZUtzYUQ0aGNMV3M/view?u...
I try your QT App , but on my LG3 i have some problem there is a big latence and some times lost sync with image. If you want test use UDP on port 9000 and if of your android phone.
In our revision of code you can view the stream , recive mavlink for telemetry and control the drone by joystick .. connect mavlink in udp mode ... with ip of the terminal ... the only think that you cannot do is start the stream and stop the stream need our api on the drone ... if you use mavproxy it is already compatible with our app
17
18
19
20
21
of 61 Next
