Airframe #1 – Flight #1 – Who’s the U-boat Commander?
To make a long story short…Flew, crashed and ended up floating in the irrigation ditch.
After 2 weeks of 20 gusting to 50 winds I finally got a chance to fly… Winds were calm, a beautiful morning to fly.
The flight was airframe only, no payload.
I did a few “power assisted” glide tests to check trim and for surprises. The aircraft was a bit twitchy due to the enlarged control surfaces, I dialed in a bunch of expo to correct the problem.
The first part of the maiden flight held no surprises other than minor trim issues. ½ throttle provided more than enough power. The flight was going well, about 7minutes into the flight I got slightly bored…
Remember the wing strength concern? I did some medium power acrobatics, Loops and rolls and was having a bit of fun. I set up for a wide open throttle low pass and watched a rocket fly by. As I pulled into the climb out, I heard a popping sound as the wing buckled between the root and tail boom.
The next 30 seconds got quite “western” as I fought the flapping wing monster for a bit of control. I ended up bouncing off the bank of the irrigation ditch as a last resort to violating my hard boundary for the flight area. The aircraft ended up bouncing over the bank and ended up floating in the irrigation ditch.
Damage done:
Buckled wing due to high speed flight
Crushed nose due to ditch bank impact.
Broken wing tip due to recovery
Dead ESC due to water.
Things I learned:
It did fly and flew well when inside its airspeed envelope.
"Felt" very stable, makes for a good aerial photography platform
Very easy to build
Wing design has structural issues
Good payload bay volume
Did not do any payload capacity (weight) tests
The picture shows where the buckling occured.
Airframe #1 has been retired
Airframe #2 is on the drawing board
Design changes/additions for Airframe #2
Longer wing, 50 inches min.
KFM3 Wing
Better wing structure, 6mm x 6mm square carbon fiber tube as a full length spar
Strengthen or change materials for tail booms
Strengthen the tailboom / wing interface
