The 3D Robotics PhoneDrone Android/RC interface board is finally in production! Pre-orders are starting now and it will ship on Oct 17th. From the product listing:
It's a way to connect any Android device (2.3.4 or higher) to the world of RC and UAVs.The board has 8 channels of RC in and out, with PWM-to-PPM conversion and multiplexing between RC and Android control. You just plug the Android's phone USB connector into the board and you have two-way communications with RC gear and any other board, such as APM.
That means that you can switch between RC control and Android control or mix the two. An example would be "fly/drive by wire". You steer your vehicle via RC, but an Android phone does the actual control using its onboard IMU. On a car, that would allow every turn to be a high-speed controlled drift, for instance (we may show something like that at Maker Faire).
Or, with a UAV, you might have the Android phone doing high-level image processing and object tracking, sending mission commands to an autopilot board such as APM. You might also want to use the phone's long-distance wireless instead of an Xbee for two-way telemetry.
This can either replace APM if you've got equivalent code running on Android, or compliment it with the Android device doing image processing or long-distance wireless comms.
It took a while to get a pick-and-place smart feeder for one of the components on this board, so apols for the delay. We're good now ;-)
You will be able to use this board as a cellular link instead of xbee, or even port APM onto your android phone since most have a full IMU+GPS, and plenty of processor power :) Looking forward to see what some members will create with this :) Our store will also be stocking this product for UK Customers, so stay tuned.
http://unmannedtech.co.uk
HI, Chris .
can you show some connection schema to the apm ?
I haven't understand if is possible to connect this board to the apm and use as cellular link instad of xbee connections .
Most probably i havent understand the "destination use" of this board .
1
2
3
of 3 Next
