After 6 months of research, development and testing, I've launched the Pi-Connect on Indiegogo. The Pi-Connect is an addon board (HAT) for the Raspberry Pi that provides easy and reliable integration with autonomous vehicles.
It provides:
- 5.1V / 3.5A power supply
- JSH-GH telemetry port for connection to a flight controller
- 2x powered UART ports in "FTDI" 0.1" headers for connection to on-board serial devices
- ADC (MCP3008) for monitoring of voltage rails or other sensors
- Power button that safely shuts down the Raspberry Pi
I'm using Indigogo to fund a small production run, so if you want a board go to https://igg.me/at/piMdxRo2YBg/x/2660470#/
Yep, I can add that to the board's documentation
Is it possible to use a pass-through header and indicate which pins are unused (if any)?
